Import dates of some movies are showing 01-01-2098!
Server Version#:1.23.3.4707
I’ve been importing movies for about 2 years into my Plex Movie DB. I Import 5 or more movies every day! After the movies are imported I alway sort my import date. I have not paid much attention to the results of the sort! Now I’ve noticed that about 30 movies out of about 900 always show up in the sort results first! This has been going on for about 6 months and really doesn’t mess anything up but it looks so odd. I decided to investigate! I went into table view and hovered over the import date of those 30 movies. Each movie shows an import date of 01-01-2098 (Which is a future date)!
Is their a quick easy fix I can do to correct this? I’ve went into the properties of those files and all date end in 2020 which is correct! Do I delete those movies from Plex and reimport them? Thanks for any response - David N.
The Plex Dance is the procedure to correct this issue.
Other than that, there is only editing the Plex SQLite database directly.
Thanks for your quick response. I will try this a bit latter and hope it works!! DN
Otto, I tried what you suggested on 3 of the movies I’m having trouble with and the results were “Perfect”!! Thanks very much! DN
