There should be an easy way to do this. I just upgraded servers, leaving my old plex server as an offsite backup.
But now my easy to get to server has nothing (other than the files) on it, and I’ve gotta remake all of those playlists by hand.
If instead it was able to export and import, that would be grand.
The issues I can think of is that the file structure is a little different between the two servers, so if it was going to “match” it should do it through the plex side rather than just “D:\Folder\File” since those can be different, but the file identification should be the same.
