So, I’m importing a large music library (20,000+ albums) into Plex and for the most part everything is going well. I use iTunes to keep folders organized and all my metadata is meticulous and correct.
The one problem I can’t seem to solve is the way Plex handles different “versions” of albums with the same title. I know Plex ignores square bracket and anything inside them, so that’s certainly at the root of the problem. Here’s an example of my naming:
/Music
/U2
/The Unforgettable Fire
/The Unforgettable Fire [Bonus Disc]
/The Unforgettable Fire [U.K. 12_]
/The Unforgettable Fire [U.K. Double 7_]
I have Local Media Assets enabled and at the top of the Agents list, and Use Embedded Metadata is checked. The ID3 tags for Album and Sort Album follow the same naming convention as the folder tree, e.g., with the information in square brackets after the album name. Track and Disc numbers are all set correctly and none are blank.
On import, what happens is that the tracks are more or less randomly scattered between the four album entries, seemingly without any rhyme or reason. Tracks belonging to the Bonus Disc end up on the Double 7", tracks from the main album are on the 12" single, etc. If I delete and reimport the albums again, say one at a time, then the addition of each album causes the existing tracks to re-sort in unpredictable ways. For example, adding just the main album works fine. Then adding the Bonus Disc causes some of the tracks from that disc to appear in the main album listing, and vice versa.
Now, I’m aware that the problem is the square brackets – as far as Plex is concerned, every album appears to be called “The Unforgettable Fire” and nothing else. My question is, I get that Plex can’t figure out how to sort the tracks based on the metadata alone – but shouldn’t there be some overriding logic that says, “When all else fails, just keep things together according to the folder tree”?
I’m guessing the answer is going to be, use parentheses instead – but that would involve renaming thousands of tracks (and even with tools like Filebot, that’s going to wreak some havoc with iTunes). Is there any other solution? And is there a reason Plex can’t simply use the folder tree as a “tiebreaker” when it doesn’t know how else to group tracks by album?
[PMS Version 1.13.8.5395 on Windows 10]
