In audio settings not possible to select channels - only stereo streaming
Hi, I want to stream 5.1 audio, but that does not work, only stereo.
After reading much forum threads I finally discovered the audio settings in PMP. Unfortunally the options device (should be HDMI of optical) and channels (2.1, 5.1 etc) can not be selected. When I try to click it, no respons as if the other option are not available.
I use PMP on Windows 10 PC, and stream through smart tv app (sony Bravia) and a pioneer receiver via ARC.
What is wrong?
Thanks!
Working fine for me on 2.47.0.
Use Enter, Esc (back), and arrow keys to navigate.
Ex: You can select Device Type with mouse. Hit Enter to show options. Use arrow keys or mouse to choose HDMI. Press Enter to set choice. Use left arrow key or Esc to move back one level. Repeat for channels, device, etc.
Ah I missed that. Use the keyboard. PMP still doesn’t like the mouse that much.
Is it so simple? Damn… I am gonna try tonight, thanks for the respons.
Thanks for showing. It’s also strange that I don’t see the passthrough options?
Change Device Type to HDMI or Optical/SPDIF. When set to Basic you do not see passthrough options (I don’t, anyway).
Thx I’ll try later today
