Incorrect Artwork Generated for Episode of Children's Show
Server Version#: 1.25.2.5319
Player Version#: Plex Web 4.72.0
Plex Media Server Logs_2021-12-24_13-57-02.zip (7.3 MB)
I imported Shining Time Station into my Plex server. The episodes don’t all have images on artwork sites to scrape from, so I assume the thumbnails were generated from the videos added.
During this add, one of the episodes somehow got a thumbnail for a random Anime?
I do not understand how this happened, as all my Anime is in a separate library handled by a separate scraper…yet somehow the data jumped between libraries and shows…
EDIT: To give importance to this, what if the image came from an Adult library.
The issue comes from TheMovieDB.com having that as the image.
Shining Time Station: Season 1 (1989) — The Movie Database (TMDB)
It will need to be corrected at TheMovieDB and then after that is done you would need to wait 24-48 hours for it to propagate to Plex’s system.
In the meantime, hover over the thumbnail and then click the edit icon (pen icon) in the bottom left corner. Click on poster and check to see if there is another image to select and click on it and then click save changes and that will update the screenshot. I believe Plex will extract a screenshot from the file all the time in case a screenshot doesn’t exist from the metadata source. However, if no screenshot exists, you could generate your own and upload that from the same dialog I mentioned.
-Shark2k
FYI… I created a request to have the image removed Reported Problem for And the Band Played Off (1x3) - Discuss Shining Time Station — The Movie Database (TMDB)
Wow, I’d only checked fan art sites pulled from and thetvdb, didn’t think to check themoviedb!
Thankfully it’s not an issue of cross library contamination!
Thanks!
