Hi, I was re-encoding a file I already had from a few years ago, and noticed while the old file displays correctly at 4:3 on the PS4, the new encode is stretched. Not the entire 16:9 frame, but its wider than the original source.
Both files are encoded as anamorphic as well. Here are the Mediainfo files for both:
Old file:
Video #1
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 11mn 18s
Bit rate : 614 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Original display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 29.606 fps
Minimum frame rate : 14.985 fps
Maximum frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(PixelFrame) : 0.060
Stream size : 49.7 MiB (75%)
Writing library : x264 core 114
Encoding settings : cabac=1 / ref=5 / deblock=1:1:1 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:0.60
Encoded date : UTC 2011-03-23 03:12:49
Tagged date : UTC 2011-03-23 03:26:59
Color range : Limited
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Video #2
Format : JPEG
Codec ID : jpeg
Duration : 11mn 18s
Bit rate : 59 bps
Width : 640 pixels
Height : 480 pixels
Frame rate mode : Constant
Frame rate : 0.001 fps
Color space : YUV
Bit depth : 8 bits
Compression mode : Lossy
Bits/(PixelFrame) : 0.192
Stream size : 7.23 KiB (0%)
Encoded date : UTC 2013-12-29 18:00:41
Tagged date : UTC 2013-12-29 18:00:42
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 11mn 18s
Bit rate mode : Variable
Bit rate : 192 Kbps
Maximum bit rate : 294 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Stream size : 15.6 MiB (24%)
Title : Stereo
Language : English
Menu #1
00:00:00.000 : Chapter 1
Menu #2
Codec ID : text
Duration : 11mn 18s
Encoded date : UTC 2011-03-23 14:56:07
Tagged date : UTC 2011-03-23 14:56:07
New Encode:
VideoCan you any reason why the Playstation 4 would display the newer file differently?
Format : AVC
Format profile : High@L4
Codec ID : avc1
Duration : 11mn 18s
Bit rate : 890 Kbps
Width : 720 pixels
Height : 480 pixels
Frame rate : 29.622 fps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.087
Stream size : 72.1 MiB (82%)
Writing library : x264 core 142 r2479 dd79a61
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=16.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=3000 / vbv_bufsize=1500 / crf_max=25.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Encoded date : UTC 1904-01-01 00:00:00
Tagged date : UTC 1904-01-01 00:00:00
Matrix coefficients : BT.601Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : ac-3
Duration : 11mn 18s
Bit rate mode : Constant
Bit rate : 192 Kbps
Bit depth : 16 bits
Stream size : 15.5 MiB (18%)
Title : Stereo / Stereo
Language : English
Tagged date : UTC 1904-01-01 00:00:00Menu
Codec ID : text
Duration : 11mn 18s
Language : English
