AWARIA
1
Server Version#: 1.32.6.7557
Hello,
Plex is downloading data to the wrong movie - it gives data from You Will Not Have My Hate (2016) — The Movie Database (TMDB), and the correct one is You Will Not Have My Hate (2022) — The Movie Database (TMDB)
Even when using the tmdb-936391 tag in the search and in the file name, the data appears incorrect.
How can I fix this - or is it only manual editing?
Plex is mixing information for the documentary and movie listings on TMDB & IMDB.
Reported to Plex. I’ll update the thread when I hear something.
Following up. You Will Not Have My Hate (2022) should now have the correct metadata. You may need to refresh metadata.
/movies/You Will Not Have My Hate (2022)/You Will Not Have My Hate (2022).mkv
Ignore the 42 second duration. I’m using a test file, not the actual movie.
