Server Version#:1.40.2.8395
Player Version#:1.91.0.129-1cd63c1d
Hi All,
Does anyone know the rules behind when TMDB data is used and when it isn’t? I have been painstakingly updating the data at TMDB, creating records when they don’t exist at TMDB and/or are incorrect on the “Plex Movie” Agent.
I then wait a day or two for the data to sync. However, when I try to match the movie to the choices given by the “Plex Movie” Agent, some data hasn’t been updated or there isn’t a separate record to select with the new record I created?
For example, I created a record “China Cat” (1978) at TMDB. All of that data is now in the selection offered by the “Plex Movie” Agent, though the year refuses to change and is still showing as “1981”.
Now I could of course manually change this, but when the scanner runs next time, it always blanks the field and gives no year?
Why has a hybrid record been created for this entry, rather than 2 records for the same movie as happens with other cases, one from TMDB and the other from the “Plex Movie” Agent?
Apologies if the terminology is incorrect above, but hopefully it makes sense? I’m just trying to get the library to be nicely synced with the correct data for each record. Surely it shouldn’t be this hard???
I reviewed this issue, which appears to be the same as mine - Movies metadata not updating after editing on The Movie Database
So I have tried this now too, but it doesn’t seem to have worked, as the year is still wrong? https://support.plex.tv/articles/202967376-clearing-plugin-channel-agent-http-caches/
I deleted the TMDB one only, should I delete more???
Cheers
