As per the instructions here I need to increase the number of directories Linux can monitor.
I’m a bit lost as math is very much not my strong point, and the way this is worded is very confusing.
B. Determine how many directories to actually allocate
Round up to the next multiple of 32768 (32K)
My Plex media folder has 16417 directories. So I round up to 32768.
C. Calculate and verify memory utlization
Multiply the number of entries from above by 512 (worst case size of an inode entry). This tells you how much kernel memory will be permanently allocated and not available to other applications such as PMS.
What does this mean by ‘entries’? It means Directories? There’s no mention of entries prior to this. So if that means Directories I multiply 32768 x 512 = 16777216
So this informs me 16777216 Kernal memory will be permantly used. What does that even mean? By that I mean what is that number in relation to actual hardware memory installed. I have 16GB
Some easy math to do this is: ( (Number_of_active_slots / 32768) + 1 ) * 32768.
Example: (53000 / 32768) => 1 ; 1 + 1 => 2; 2 * 32768 = 65536253000 / 32768 = 7 (drop the fraction)
7 + 1 = 8
8 * 32768 = 262144
yeah, you lost me completley here. 7+1=8 (That I understand hah , but why is that even in there? That’s rhetorical btw).
So my question:.
I have 16417 directories and 16GB memory. What number should I put into NEW_MAX_DIRECTORIES ??
fs.inotify.max_user_watches=NEW_MAX_DIRECTORIES
Any help appreciated!
