Indexing subs multiple times
Hi! I have a question. Can you tell me if the indexing is having issues with subtitles? After indexing everything, for movies with 2 subs, in the selection menu a huge list appears repeating the same 2 subs over and over again.
Thanks for your help!
I would need to see the scanner logs and the local media agent logs.
Hi!, thanks for your quick response. I am sending you the logs as requested. Thanks in advance!
Plex Media Server Logs_2018-07-25_09-41-04.zip (3.9 MB)
Hi, this is what I see when trying to select the subs.
More info, thay may help to fix this.
  1. This does not ocurr on every movie
  2. When removing movie identification, then the subtitles options are shown without any issue.
  3. As soon as I try to identify the movie with Plex Movie or The Movie Database agents then the large subtitle list appears.
Hope it helps to solve the issue,
thanks
