Indirect only remote access on Synology DS918+
Server Version#: 1.17.0.1841
Once enabled, remote access will go green, then switch to red after a few seconds.
Local connections work fine. Only able to connect indirectly outside of LAN.
I have tried everything I have come across on the forums and Google.
Switching to Synology NAS from VMware VM (Fedora 30).
Remote Access worked fine on the VM.
  • Xfinity Gateway with Advanced Security disabled
  • DHCP reservation and manual port forward. No double NAT
  • Static IP set on Synology to match DHCP reservation.
  • Static DNS IPs set on Synology, matching default Comcast IPs (75.75.75.75…)
  • IPv6 disabled on NAS and Plex UI
  • Synology firewall disabled
  • Manual port set in Plex UI (32400)
  • CanYouSeeMe.org reports success on port 32400
Background on me: Seasoned Linux/VMware Admin with years of networking experience.
Currently and AWS Architecture Engineer.
Any help would be much appreciated.
Thank you in advance,
Nick
Remote access works, but only via indirect. I have a few friends who access my server via remote access. While they are watching I can see they are connected indirectly in the dashboard and limited to SD (2 MB/s) quality.
I have tried both DHCP and static IP, also Comcast DNS and Google DNS.
Same result, indirect remote access only.
Nick
Please read above.
Remote access (direct) worked perfectly fine running on my VMware VM. Same network, same router/gateway. Same HDCP reservation system and port forward method.
The only different is the application platform. My old server was running on a VMware VM. My new server is running on Synology native application. Newest plex pass version directly from plex.tv.
Nick
Sorry for the delay, got busy and had to put this on the back burner.
Was at a friends house yesterday and he asked why he gets the indirect message now when streaming from my server. Reminded me to pick this back up.
Everything streams fine from my LAN, but remote access is always “indirect”
Even though “canyouseeme.org” reports an active connection on the port I have forwarded.
Thank you,
Nick
Plex Media Server Logs_2019-10-20_13-50-41.zip (1.1 MB)
Ah sorry about that. I turned that off a while back. Just re-enabled it. Then disabled and enabled remote access. It will show green check mark for a few seconds, then switch to red X and stay there.
New logs attached.
NickPlex Media Server Logs_2019-10-20_16-51-36.zip (1.1 MB)
I think I figured it out. The firewall on my xFi gateway was set to minimal (default) with enables some kind of IDS function along with some basic port blocking. I disabled this and now am able to connect directly while remote. I don’t believe I had to make this change while running on my old server. Maybe Comcast switched on the IDS feature by default a while back.
Anyway, all seem to be working correctly now.
Thanks for taking a look at the logs.
Nick
