recently can access my server via indirect and seems ok from testing
but formatted pc and then noticed no longer indirect… great
but today its gone back to indirect
any advise, changed its port or something on router? i have port forwarded etc
ty
ty
direct and now indirect i can still stream, over the web but presume direct is preferred better?
relay = indirect.
ok ty but why has it changed over night?
check everything on the linked troubleshooting page.
can’t really help you much without any logs or anything.
didnt really want to faff about with port forwards as it should work as did work. now my friend also cannot see my server.
very strange that something has changed over night. i though as i installed a vpn client but that wasnt running and now uninstalled
If you don’t want to provide logs, I doubt there’s much any of us can do for you.
I would always advise using a static IP and port forwarding for the most stable connection. UPnP is flaky at the best of times.
its now switched back to being direct, nothing has changed again my end
