Installing channels manually on rasplex?
Is it possible?
I installed the two I’m interested in on my plex server and they work fine through the web interface, however, when I try and run media through them on rasplex, it tells me the file cannot be found.
I’m guessing the files download locally whilst they stream, and because the location on the server isn’t mounted to rasplex it cannot find the file to stream…
All channels are handled by PMS, you cannot add them to clients, which channels are causing issues, have you raised the issue with the Channel developer?
Regards
Regards
Yes I’ve raised them on the relative threads.
I’m having a problem with tunein radio and filmon (which are installed on the server), when I play a stream I get a message to say the file is not found and the directory may not be mount. But when I use it via the web or via the iOS app they both run fine.
All sorted now.
