Interface way too large after update
Player Version#:2.58.0.1076
It seems an update happened and I had to reassociate the player with my account. So far so good only that the interface is kinda zoomed in. I have two and a half tiles of “watched recently” content and part of the first row of tv shows. The menu on the left doesn’t fit on the screen either.
Is there a keyboard shortcut to change this? I couldn’t find anything in settings.
Which native screen resolution is set at the operating system level?
Do you have set a “zoom level” or changed the text size at the operating system level?
Are you using a customized shortcut to start PMP, with added command line parameters?
This is FulHD and I had scaling set in Windows.
However changing that back does very little to alleviate the problem.
I’m not sure what exactly you mean by “zoom level”.
And doubleclick for fullscreen doesn’t work anymore either…
I am getting used to the fact that every company out there has it made their mission to make their UI as unusable as possible but Plex is in a league of its own…
You know what, ■■■■ this. I officially have no mor use for this crapware.
