Intermittent "An Unexpected playback problem" on LG G1
Server Version#: 1.23.6.4810
Player Version#: 5.20.1
Platform Version#: 6.1.0
I seem to be getting intermittent An unexpected playback problem has occurred on my LG G1 webOS app. These errors are completely intermittent. As soon as I back out and try playing the exact same media, it works perfectly. It happens when I initiate playback, and after I retry and finish the episode and move to the next one, it will usually happen again. It does not happen every time, and I cannot figure out how to consistenly reproduce it. It’s mostly just annoying. I have not noticed it on other platforms, though I do not watch enough on anything other than webOS to verify that it only occurs on that version. Debug logs from the client below.
Jul 21, 2021 22:34:00.101 [0x799ce5029b38] INFO - [Plex for LG] [redacted] Navigating to screen: VisualMediaPlaybackScreen
Jul 21, 2021 22:34:00.101 [0x799ce5029b38] INFO - [Plex for LG] [redacted] [PlaybackMetrics] Attaching playback metrics to PlayerController
Jul 21, 2021 22:34:00.101 [0x799ce5029b38] INFO - [Plex for LG] [redacted] [PlaybackSessionController] playback state changed to: stopped
Jul 21, 2021 22:34:00.101 [0x799ce5029b38] INFO - [Plex for LG] [redacted] [SubtitleConnectionManager] Subtitle connection ignored. App is not rendering subtitles.
Jul 21, 2021 22:34:00.101 [0x799ce5029b38] INFO - [Plex for LG] [redacted] [ServerConnectionTestManager] Stopped
Jul 21, 2021 22:34:00.101 [0x799ce5029b38] INFO - [Plex for LG] [redacted] Navigated to screen: VisualMediaPlaybackScreen
Jul 21, 2021 22:34:00.101 [0x799ce5029b38] WARN - [Plex for LG] [redacted] _onOnPlayPauseInvokedChanged is not defined for @autoCallback property: onPlayPauseInvoked
Jul 21, 2021 22:34:00.101 [0x799ce5029b38] INFO - [Plex for LG] [redacted] [MDE] Application decision, directPlay: false, directStreamVideo: false, directStreamAudio: false
Jul 21, 2021 22:34:00.101 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     Cannot direct play with protocol: http, codec: truehd.  Not found in profile.
Jul 21, 2021 22:34:00.101 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     Cannot direct stream with protocol: hls, codec: truehd.  Not found in profile.
Jul 21, 2021 22:34:00.101 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     Cannot direct play or stream. Server does not support transcoding subtitle codec pgs
Jul 21, 2021 22:34:00.101 [0x799ce5029b38] INFO - [Plex for LG] [redacted]   videoStream: {
  "id": 1296393,
  "streamType": 1,
  "default": true,
  "codec": "hevc",
  "index": 0,
  "bitrate": 7026,
  "language": "English",
  "languageCode": "eng",
  "bitDepth": 10,
  "chromaSubsampling": "4:2:0",
  "codedHeight": 1080,
  "codedWidth": 1920,
  "colorPrimaries": "bt709",
  "colorRange": "tv",
  "colorSpace": "bt709",
  "colorTrc": "bt709",
  "frameRate": 23.97599983215332,
  "height": 1080,
  "level": 150,
  "profile": "main 10",
  "refFrames": 1,
  "width": 1920,
  "displayTitle": "1080p (HEVC Main 10)",
  "extendedDisplayTitle": "1080p (HEVC Main 10)"
Jul 21, 2021 22:34:00.101 [0x799ce5029b38] INFO - [Plex for LG] [redacted]   audioStream: {
  "id": 1296394,
  "streamType": 2,
  "selected": true,
  "default": true,
  "codec": "truehd",
  "index": 1,
  "channels": 6,
  "audioChannelLayout": "5.1(side)",
  "bitDepth": 24,
  "samplingRate": 48000,
  "displayTitle": "English (TRUEHD 5.1)",
  "extendedDisplayTitle": "English (TRUEHD 5.1)"
Jul 21, 2021 22:34:00.101 [0x799ce5029b38] INFO - [Plex for LG] [redacted]   subtitleStream: {
  "id": 1296396,
  "streamType": 3,
  "selected": true,
  "default": true,
  "codec": "pgs",
  "index": 3,
  "headerCompression": true,
  "title": "Signs / Songs",
  "displayTitle": "English (PGS)",
  "extendedDisplayTitle": "Signs / Songs (English PGS)"
Jul 21, 2021 22:34:00.101 [0x799ce5029b38] INFO - [Plex for LG] [redacted] Cannot direct play subtitles. Reason: Server required to burn subtitles
Jul 21, 2021 22:34:00.101 [0x799ce5029b38] INFO - [Plex for LG] [redacted] [MDE] Server decision, directPlay: false, directStreamVideo: false, directStreamAudio: false
Jul 21, 2021 22:34:00.101 [0x799ce5029b38] INFO - [Plex for LG] [redacted]   reason: App cannot direct play this item. Direct play is disabled.
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]   videoStream: {
  "bitrate": "8859",
  "codec": "h264",
  "default": "1",
  "extendedDisplayTitle": "1080p (HEVC Main 10)",
  "frameRate": 23.976,
  "height": "1080",
  "id": "1296393",
  "streamType": 1,
  "width": "1920",
  "decision": "transcode",
  "location": "segments-av"
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]   audioStream: {
  "bitrate": "375",
  "bitrateMode": "cbr",
  "channels": 6,
  "codec": "aac",
  "default": "1",
  "extendedDisplayTitle": "English (TRUEHD 5.1)",
  "id": "1296394",
  "selected": "1",
  "streamType": 2,
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]   subtitleStream: {
  "burn": "1",
  "default": "1",
  "extendedDisplayTitle": "Signs / Songs (English PGS)",
  "id": "1296396",
  "selected": "1",
  "streamType": 3,
  "decision": "burn",
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]   augmentations with profile: Generic
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     add-transcode-target streaming videoProfile hls mpegts h264,hevc,mpeg2video,mpeg4 aac,ac3,eac3,mp2,mp3
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     add-limitation videoAudioCodec mp2 upperBound audio.bitrate 350
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     add-limitation videoAudioCodec mp3 upperBound audio.bitrate 350
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     add-limitation videoCodec h264 upperBound video.level 51
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     add-limitation streaming videoTranscodeTarget h264 hls upperBound video.bitDepth 8
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     add-limitation streaming videoTranscodeTarget h264 hls upperBound video.width 3840
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     add-limitation streaming videoTranscodeTarget h264 hls upperBound video.height 2160
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     add-limitation streaming videoTranscodeTarget hevc hls upperBound video.bitDepth 10
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     add-limitation streaming videoTranscodeTarget hevc hls upperBound video.width 3840
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     add-limitation streaming videoTranscodeTarget hevc hls upperBound video.height 2160
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     add-limitation streaming videoTranscodeTarget mpeg2video hls upperBound video.bitDepth 8
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     add-limitation streaming videoTranscodeTarget mpeg2video hls upperBound video.width 1920
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     add-limitation streaming videoTranscodeTarget mpeg2video hls upperBound video.height 1080
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     add-limitation streaming videoTranscodeTarget mpeg4 hls upperBound video.bitDepth 8
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     add-limitation streaming videoTranscodeTarget mpeg4 hls upperBound video.width 1920
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     add-limitation streaming videoTranscodeTarget mpeg4 hls upperBound video.height 1080
Jul 21, 2021 22:34:00.102 [0x799ce5029b38] INFO - [Plex for LG] [redacted]     add-transcode-target all subtitleProfile http pgs
Jul 21, 2021 22:34:00.103 [0x799ce482bb38] ERROR - Missing required query parameter level
Jul 21, 2021 22:34:00.106 [0x799ce625fb38] ERROR - Missing required query parameter level
Jul 21, 2021 22:34:00.112 [0x799ce5029b38] ERROR - Missing required query parameter level
Jul 21, 2021 22:34:00.117 [0x799ce482bb38] ERROR - Missing required query parameter level
Jul 21, 2021 22:34:00.128 [0x799ce625fb38] ERROR - Missing required query parameter level
Jul 21, 2021 22:34:00.128 [0x799ce5029b38] ERROR - Missing required query parameter level
Jul 21, 2021 22:34:00.133 [0x799ce482bb38] ERROR - Missing required query parameter level
Jul 21, 2021 22:34:00.136 [0x799ce625fb38] ERROR - Missing required query parameter level
Jul 21, 2021 22:34:00.141 [0x799ce5029b38] ERROR - Missing required query parameter level
Jul 21, 2021 22:34:00.142 [0x799ce482bb38] ERROR - Missing required query parameter level
Jul 21, 2021 22:34:00.154 [0x799ce625fb38] ERROR - Missing required query parameter level
Jul 21, 2021 22:34:00.172 [0x799ce5029b38] ERROR - Missing required query parameter level
Jul 21, 2021 22:34:00.220 [0x799ce482bb38] ERROR - Missing required query parameter level
Jul 21, 2021 22:34:00.227 [0x799ce625fb38] ERROR - Missing required query parameter level
Jul 21, 2021 22:34:00.228 [0x799ce5029b38] ERROR - Missing required query parameter level
Jul 21, 2021 22:34:00.229 [0x799ce482bb38] ERROR - Missing required query parameter level
Jul 21, 2021 22:34:00.229 [0x799ce625fb38] ERROR - Missing required query parameter level
Jul 21, 2021 22:34:00.262 [0x799ce6452b38] ERROR - Error issuing curl_easy_perform(handle): 7
Jul 21, 2021 22:34:00.277 [0x799ce625fb38] ERROR - Missing required query parameter level
Jul 21, 2021 22:34:05.211 [0x799ce5029b38] INFO - [Plex for LG] [redacted] [SubtitleConnectionManager] Subtitle connection ignored. App is not rendering subtitles.
Jul 21, 2021 22:34:05.211 [0x799ce5029b38] INFO - [Plex for LG] [redacted] [PlaybackSessionController] playback state changed to: buffering
Jul 21, 2021 22:34:06.617 [0x799ce637db38] ERROR - Error issuing curl_easy_perform(handle): 7
Jul 21, 2021 22:34:06.617 [0x799ce6452b38] ERROR - Error issuing curl_easy_perform(handle): 7
Jul 21, 2021 22:34:06.617 [0x799ce6128b38] ERROR - Error issuing curl_easy_perform(handle): 7
Jul 21, 2021 22:34:06.617 [0x799ce63a0b38] ERROR - Error issuing curl_easy_perform(handle): 7
Jul 21, 2021 22:34:11.047 [0x799ce482bb38] WARN - [Plex for LG] [redacted] [Player] A critical HTML media error occurred: 4 (MEDIA_ELEMENT_ERROR: Format error); the player cannot recover
Jul 21, 2021 22:34:11.047 [0x799ce482bb38] INFO - [Plex for LG] [redacted] [PlaybackSessionController] playback state changed to: stopped
Jul 21, 2021 22:34:11.047 [0x799ce482bb38] ERROR - [Plex for LG] [redacted] Playback error occurred. Reason: Unknown, An unknown player error occurred. code: 4, message: MEDIA_ELEMENT_ERROR: Format error
Jul 21, 2021 22:34:11.047 [0x799ce482bb38] WARN - [Plex for LG] [redacted] [PlaybackSessionController] could not retry, reporting error
Jul 21, 2021 22:34:11.047 [0x799ce482bb38] INFO - [Plex for LG] [redacted] Opening modal: ActionsModal
Jul 21, 2021 22:34:11.047 [0x799ce482bb38] INFO - [Plex for LG] [redacted] Opened modal: ActionsModal
Jul 21, 2021 22:34:11.047 [0x799ce482bb38] INFO - [Plex for LG] [redacted] Navigation: Closing screen: VisualMediaPlaybackScreen
Jul 21, 2021 22:34:11.047 [0x799ce482bb38] INFO - [Plex for LG] [redacted] goBack on screen: VisualMediaPlaybackScreen
Jul 21, 2021 22:34:11.047 [0x799ce482bb38] INFO - [Plex for LG] [redacted] Navigating back to screen: ShowTabbedScreen
I’m getting the same error message on an LG nano 85.
Server: 1.23.5.4841
Client: 5.20.1
Platform: 5.2.3
EDIT: I’m no longer receiving this error with Server # 1.23.5.4862
Im getting the same errors on my Samsung Q95 TV:
Server: 1.23.6.4881-6000 (installed manually on Synology NAS)
Client: 5.20.1
Platform: 5.5
All movies appear to play correctly on my Android phone, but not on the Samsung TV.
I have tried deleting the TV Plex APP and reinstalling … still no luck.
Any ideas out there?
