Intro detection is hanging
Using latest beta, running windows 10.
Intro detection, while rather slow at times… works fine.
However last night it seemes to have got stuck on scanning the same show but as two seperate notifications…
It’s been like that about 9 hours…
Circle icon is not moving, seems to just be frozen.
Plex is working fine otherwise.
Rebooting the computer fixed the issue.
Unsure if it was an issue with that one show
Reboot no longer fixes.
Issue remains, happening on every single show.
ANYONE at Plex give a ■■■■?
Issue remains. any single tv show will cause is to hang
Post your logs with debug enabled. No one is going to have any idea what may be going wrong without your logs.
Intro detection is a fairly new feature and seems to have some bugs to be worked out still. I can’t even use it without it crashing my servers.
Hopefully Plex can get you fixed up once you share your logs.
Will do. Disabling intro detection does not even disable it, it continues.
Messy
