iOS Live TV No Sound Outside Home Network
Streaming Live TV from HDHomeRun outside of our home network sound no longer works.
Streaming Live TV from HDHomeRun inside of our home network sound works.
Streaming anything else but live TV from HDHomerun outside of our home network sound works.
Used to work just fine. I assume stopped working after server and/or app updates.
Server Version#: 1.41.6.9685
Player Version#: 2025.15.0 (1053)
Tuner Make/Model: HDHomeRun CONNECT QUATRO
Channel number/Name: All
I believe this is the same issue you’re experiencing:
https://forums.plex.tv/t/new-ios-app-2025-15-0-1053-forced-audio-ac3-transcode-to-opus-results-in-no-sound/
Appears so.
Changed the Video & Audio Cellular quality from 2.0 Mbps to 12 Mbps and transcoding goes to Direct Stream from OPUS and sound plays. Not ideal solution for my use.
Any update to this issue. Changing my quality to 12Mbps also made sound start to work, but using less bandwidth would be better.
Sadly just like the guide issue, Live TV get’s little attention. Appears they are actually investigating (after weeks of it being an issue for everyone) the EPG issue…no feed-back on the audio side.
Yes, Finally version Plex IOS 2025.22.0 sound is back local network and Remote Access.
HDHomeRun CONNECT QUATRO, and UNRAID Plex Docker
