Server Version#: 4.33.1 running on macOS 10.9.5
Player Version#: Plex 6.10.1 & Plexamp 3.0.2 on iOS 12.3.1
For each track it skips it generates the error:
Exception handled: bad lexical cast: source type value could not be interpreted as target
All tracks in this particular album were created with youtube-dl (which used ffmpeg to encode to AAC saved with an m4a extension). Some tracks work, others are skipped completely. All tracks play fine in the desktop browser Plex client (and Music.app). Here’s the info for a track that gets skipped:
Besides the variable bitrate the only difference I see is the one that plays is Web Optimized. But this track is also Web Optimized but gets skipped so that’s probably not it:
I’m not on ios, I use android but I just switched to .aac for my music and I’m having the same problem. Just skips seemingly random songs while they play fine on other players. On both the plex app and plexamp.
Plex for iOS and Android, as well as Plexamp all use the same player engine (which was developed during the Plexamp development, but shipped first in the “normal” apps, fun fact!), so you’ll probably see the same issues on all of them for things like that. Do you have a sample file you can reliably reproduce this with?
So not all of my library has been re-ripped yet, only the new .aac files do it, so there’s samples spread out throughout the new ones. I’ve tried seeing if aac in the .m4a container would fix it but it makes no difference. Here’s two, one .m4a and one just raw .aac Samples.zip (19.8 MB)
I’ve faced the same issue, but it doesn’t seem as though the issue is file format specific. I first noticed tracks being skipped to the last few seconds on the track being played when I was using VLC as the player over DLNA. I’ve since moved to Plexamp on both my desktop and Android phone (hoping that that would solve the problem) but the issue seems to have become worse - almost every album I play has a playback issue of some kind. Most of my music collection is in flac, encoded with SoundJuicer on Linux.
If there is any further information I can provide, happy to upload logs, media files, etc.
