iOS Server settings not showing up
Server Version#:
I was having some issues today on my iPad while working on some things remotely. To try and work around the issues I went to network settings and turned “secure connections” to Disabled. The minute I did this my server disappeared and I am no longer able to access anything on the iPad web browser or the plex app. Every other tv, computer or iPad still works just not mine. I know the fox is easy as I just need to go back and change secured connection to “preferred”. Problem is I can no longer do that on the browser or app as neither has a network option under settings. I’ve tried putting in the IP address and still nothing. Something so easy and I’m clueless what to do.
if you disabled secure connections then you need to use the http://local.IP.address:32400/web when on same network. “app.plex.tv” only works with secure connections.
if you are on iOS14 or higher I think you need to give permission to app to allow it to local network devices.
I have a problem with my iOS 15.0.1, the application cannot be working and the server in my WD-My Cloud is offline , but when I tried to use http://local.IP.address:32400/web in my browser in iPhone it works good.
I hope you can fix the application issue with iOS 15
