IP vs Localhost
Hi guys,
My PLEX is misbehaving and its a weird problem.
If I access PLEX via 192.168.1.4, or via the android app, the home page will not load and the circle keeps going round.
If I access if via LOCALHOST, all works fine?
RemoteAccess ports are fine and shows accessible.
Its broken and I really dont want to reinstall and set the entire thing up again.
Any suggestions?
Check firewall and/or AntiVira solution
I have no firewall and Antivirus removed.
Did you verify, that the box running PMS hasn’t switched IP?
And did you check settings\Network\Preferred network interface ?
I just checked. It was set to ANY and it only had one more option. Set it to the second option of 192.168.1.4.
I will now reboot and report back to see what happens.
UPDATE. Not made a difference :frowning:
Also, downloaded the latest version and did a repair, reboot, no difference.
Then let’s stop guessing here, and upload logs :wink:
Apologies but where is it? In DEBUG?
https://support.plex.tv/articles/226836308-help/
As requested :slight_smile:
Plex Media Server Logs_2019-04-14_22-57-30.zip (2.5 MB)
Adding a whole chunk of photos, before reporting this is not optimal!
(Logs roll over, and get’s drowned in photo req. entries)
Allow your photo scanner to finish, then reboot, and try again.
And after that, upload logs again
Remote access issues here as well - has been working mostly fine for over a year and now its started breaking, failed 2 days ago - worked again yesterday, failed again today. No connectivity issues - Plex remote just doesnt want to work consistently, all other services on server running no issue.
UPDATE.
Looks like many are experiencing this. No fix at the moment…?? WEBAPP requires an update as discussed here:
Was working again last night after this post ?. I refuse to believe this is a local issue, something must be happening around network configuration in plex.tv
