Server Version#: 1.43.2.10687
Hi all
when I double click on the plex system tray icon, it normally locals localhost:32400 but now it just is stuck on the plex screen and nothing loads.
the url is 127.0.0.1:32400/myplex/launch?X-Plex-Token=local-f1ctwa21-6314-435b etc
I have to go onto app.plex.tv to load my server. with this I cannot locally stream things on my pc but the media server is running and operational. I am able to play plex on my devices in my house and also remote play anywhere in the world. I just cannot get local server to launch.
hi, i checked that and i do have local network access ticked.
when i check the local host it says it is insecure. it was working and then all of a sudden it stopped. i couldnt even access radarr or any other program that uses localhost. are there any other places i can check? i went into chrome and allowed all the options and connections but still not loading
There was an issue several months back on Windows, after a windows update, where localhost/127.0.0.1 stopped working. It was fixed, but maybe your system hasn’t updated since that update?
Can you access it via http://<serverip>:32400/web? Replace server ip with the ip of the computer.
I guess these are one of those enigmas. I’m going to be movie upgrading my setup to unraid and then will run everything off there. So not a major train smash but it’s annoying. I guess it’s a minor trade off for finally getting my remote access working flawlessly after ages.
