Hey guys,
my 5th gen Intel NUC isnt able to play 4k content to mny Sony Bravia X9005C. I love the NUC because its so tiny, power efficient (only 15Watts) and silent.
Thas why im looking for a new NUC.
So… Does anyone alredy have experience with the new 7th gen core intel NUC products? I want to choose the i5-Version like this:
Does 4k Content (x264 and x265) plays smooth without framedrops?
Yes, but last I heard, it has issues bitstreaming HD Audio in Linux/Embedded plex (Win10 is okay). There was rumors of a fix, but I don’t know if it was ever implemented.
For embedded PMP:
The HD audio passthrough fix will come with a rebase—when LE9 final is released. However the Kaby Lake’s iGPU’s OpenGL rendering performance is lackluster. I have been debugging this issue for several months now. Its either lack of optimization for Kaby Lake’s iGPU by Mesa; or mpv needs some development for Kaby Lake’s iGPU.
@jjrjr1 said:
That CPU has a Passmark of 6000
Nowhere near enough to transcode HEVC 4K
If you encode your 4K to Direct Play… Then you will be OK
I believe the OP’s intent is for PMP client playback and not for PMS. It will HW decode 4K HEVC HDR10 but will perform tone-mapping. PMP does not yet support native HDR10 output.
The Kaby Lake’s QSV ASIC supports 4K HEVC HDR10 decoding and can transcode it to H.264 SDR in hardware. PMS has HW transcoding for this already. Passmark would only matter if attempting to SW decode/transcode.
@eizdieler If your intent is to play 4K UHD BD remuxes, your better choices at the moment are the AppleTV 4K or the nVidia SHIELD TV. These both can decode and output 4K HEVC HDR10 to your 4K TV.
@Achilles said: @eizdieler If your intent is to play 4K UHD BD remuxes, your better choices at the moment are the AppleTV 4K or the nVidia SHIELD TV. These both can decode and output 4K HEVC HDR10 to your 4K TV.
@Achilles ive read about apple tv 4 doesnt support 7.1 channel audio?
im using the NUC as PMS & PMP. And yes i want “direct play” to my sony bravia UHD-TV.
BTW the sony android tv pmp-app also supports 4K video, but when watch movies with it (h265) i imagine a lot of framedrops and stuttering. dont know why. the netflix app with 4k content works flawless. anyways.
So guys thanks to all, lemme try this ■■■■ i will by the latest kaby lake NUC system and set it up
I have a server with an I7 kaby
I don’t generally use it for PMP as I have an HTPC ryzen but with a with GTX 960 (i think) attached. Both do a stellar job with all these HDR 4K remuxes that are appearing.
Edit. When you get set up don’t forget to enable HW decoding in PMP.
So guys thanks to all, lemme try this **** i will by the latest kaby lake NUC system and set it up
FYI, I just bought a Sony X800E and the Android Plex client on that plays back UHD rips perfectly. Mine is connected to gigabit Ethernet. Initially got a lot of frame drops and stuttering too, but quickly realized my Plex settings were forcing the server to transcode video stream. After fixing my settings everything played back perfectly.
naaa. my current PMS isnt able to transcode UHD streams (an older Intel NUC with i5) so its definitly directplay. maybe the TV decodechip is a little to slow (X9005C). i also imagine these effects while plying some uhd youtube videos but never with netflixx.
my tv is also connected via gigabit. a logfile on the tv would be great does the pms maybe have a log with detailed stream errors?
my tv is also connected via gigabit. a logfile on the tv would be great does the pms maybe have a log with detailed stream errors? @eizdieler Do you want to view it in true HDR? PMP is not capable of this currently on any hardware. It will HW decode and tone-map to SDR before output to the display.
Sony X9005c = MediaTek MT5890
Sony X800e = MediaTek MT5891
So that might explain the difference…
@Achilles said: @eizdieler Do you want to view it in true HDR? PMP is not capable of this currently on any hardware. It will HW decode and tone-map to SDR before output to the display.
Are you talking about embedded PMP only? When using the Android TV client it seems to play HDR w/o transcoding.
Also, I have played with many, many clients (including a current gen Apollo Lake NUC). I can’t recommend the Nvidia Shield enough as a client. Plays everything, lightning fast, it is like, wow!
As far as NUCs are concerned, the roadmap indicates some significant updates later in 2018 (Coffee Lake Quad core CPUs, improved graphics, etc). I would hate to buy one right now, but if you need something now here’s a review of a NUC-like box from my favorite Plex advocate:
I am talking about Plex Media Player on Embedded LE, macOS, Linux and Windows. It does not output HDR. The backend is mpv and it currently tone-maps HDR to SDR.
Hence it was one of the recommendations to the OP for playback. He does not seem to be to concerned about watching HDR content.
Me personally, I cannot recommend the Apple TV. I bought 2 when the fourth GEN came out, and there have been a lot of Plex playback issues. Have not tried the 4K, but probably won’t since the Plex playback issues are fundamental to the embedded Apple player. That and the fact that Apple does not support DTS.
Infuse Pro on AppleTV 4K is what I use to play my 4K HEVC HDR10 content. Infuse is a full fledged 3rd party player by FireCore with fully licensed decoders for all video and audio codecs. Works perfectly fine. Supposed Plex client integration coming with v5.7 soon.
mhh dont understand. you cannote compare apollo lake with a kaby lake plattform? its intel atom cpu vs. core i5 with hardware based 4k decoding features?
Sorry about not being clear, I meant there are some big upgrades in the pipeline for the Core-series NUCs (Bean Canyon/Coffee Lake-U) in 2018. They are moving from dual core to quad core CPUs:
hey guys. quick update. got my new NUC and installed PMS / PMP on windows 10. 4K movies are played absolutly smooth with no framedrops or stuttering. awesome i love kaby lake
