Is there a problem with Live TV and Plex Server 1.9.3.4290?
I just bought an HD HomeRun Connect to connect to a Plex server. It seems to run fine when I connect it to my 64-bit server running Plex 1.9.2.4285. However, when I try it on my 32-bit server running Plex 1.9.3.4290, I get audio with no video. Is this a known problem? I can’t find the older 32-bit version of Plex (1.9.2.4285) to try it on my 32-bit server.
Additionally, if I try to record a show on the 32-bit server, the server crashes and I must restart that server.
What OS are you running?
yes it is an issue with 1.93. if you look into your plex media server folder there is a folder called updates. inside that should be 1.92 on your 64bit server.
1.9.3 has a bug affecting live/dvr recordings. Being worked on but not fixed yet. For now run 1.9.2.
This is a newly configured Linux 32-bit server and the only option I had was to download Plex Server 1.9.3.4290.
Sounds like I need to find the 32-bit debian Plex 1.9.2 install for Ubuntu Linux.
Anyone know where to find Plex 1.9.2 install for Ubuntu?
