Is there a way to stop or pause Plex server or it's processes?
Server Version#: 1.40.1.8227
Here’s the problem: I need to reconfigure an external RAID5 with about 12TB of Plex data on it, but I can’t turn off the computer. To reconfigure, I have to backup, destroy and reload the data. That would drive Plex server crazy. If I could turn off the server while I do the work, then I could turn it back on without Plex even knowing about it. The plan is to copy the data to another RAID and move it back.
So, is there a way to gracefully stop and restart the server? I can see in Task Manager that there are four processes. I could stop those, but is that the only way to put Plex to sleep? It seems rather inelegant.
That’s always been possible through the Plex task tray icon.
grafik
If you are running Plex as a system service (not the default), you need to stop its service.
Thanks! I used the Google and I didn’t see that appear in any of the results. I really do try to do my own research before asking here. I even searched the support site. I’m not saying it isn’t there. It’s just that the search engines weren’t helpful.
I run the default setup. I’m not smart (or energetic) enough to do otherwise.
Thanks again. You folks to good work and I appreciate it.
