Hello, just a bug report, maybe this is the wrong section… When adding my cable tuner to plex DVR which already had OTA tuner installed, it didnt ask for zipcode and tried to use channel guide already in use, only 2 channels auto-selected and they were incorrect matches. Had to delete the entire DVR and start from scratch with Cable one first… not adding in OTA for now, better quality from Cable anyways
Not a bug, by design. DVR can only have one channel guide. Whichever device you add first as you found out will determine the guide used by all devices. Currently can’t create multiple DVR’s in the web interface. Hopefully the ability to add multiple DVR’s with different guide data but the same recording schedule is in the plans.
@johnm_ColaSC I see you have both a connect and a prime in your siggy. Based on the answer you just gave … are those both working? Or do you just list them because you have them?
Actually have 2 Connects, a Prime, and a Dual. Connects and Prime are hooked up. Prime is only used for local channels that cable company rebroadcasts. Had Dual hooked up at one time but disconnected when issue with only one tuner on it recording. At the time would have rather known about conflicts and adjusted than have Plex fail to record a show because it didn’t use the 2nd tuner on the Dual.
