Issue: Automatically Adjust Quality is causing playback to be too fast on Android
Server Version#: 1.25.2.5319
Player Version#: 8.27.1.29871
When I turn on “Automatically adjust quality” the shows and movies play at a much higher speed than normal. If I turn off the setting, the shows then play at normal speeds.
Edit - It doesn’t happen if the stream is a direct play. I also have “hardware acceleration” turn on at the server, if that matters.
Any ideas?
