Server Version#: 1.21.0.3744
I am getting a notification to upgrade my library. When I click to upgrade I get a popup box that says “there was a problem upgrading the library” Any solutions?
Try manually setting both the scanner and agent to “Plex TV Series” in the library’s advanced settings:
If it allows you to save that, perform a “Refresh All Metadata” on the library so that metadata for your existing series is refreshed from the new agent.
Try making the changes via the web client at https://app.plex.tv.
Are you running DSM 7?
1.21.0.3744 is an early beta release and not fully compatible with the current version of DSM 7.
Download the current version from plex.tv and perform a manual update.
See DSM 7 - Packaging 2.0 (PMS 1.24.2.4973) - Release information for additional details.
The FAQ also has helpful information: Synology FAQ - Questions, Answers, and a few How-To’s
Thanks for the info when I try to install the update it is asking for a specific file on my NAS
The .spk file you downloaded from plex.tv.
Don’t unzip/uncompress or navigate into the .spk file. You want to upload the entire file to the NAS.
Thanks I have installed the update and followed the directions to give read/write access to all the folders that my plex media files are in but now I cannot connect to those files when bringing
up plex
All good now…thanks!! just took a little while for Plex to update on my NAS. Thanks again!!
