Issues with Dolby Vision on LG TV
I am playing movies from my local Plex server to my LG TV that supports Dolby Vision, yet I still get the wrong color (pink/blue) when playing DoVi files. Could one of you gurus please lend some advice? Is my TV not working correctly?
-=Plex Media Server=-
1.32.7.7621
-=Viewing Device=-
-Television-
LG - 77" Class G2 Series OLED evo 4K UHD Smart webOS TV with Gallery Design
“Dolby Vision IQ: Yes”
“HDR (High Dynamic Range): Cinema HDR (Dolby Vision, HDR10, HLG) Dynamic Tone Mapping Pro”
-Plex for LG-
Client Version: 5.72.3
Platform Verision: 7.3.1
-=MedioInfo Result of the file being played=-
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@High
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Codec ID : V_MPEGH/ISO/HEVC
Duration : 1 h 56 min
Bit rate : 24.7 Mb/s
Width : 3 840 pixels
Height : 2 076 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.129
Stream size : 20.1 GiB (98%)
Default : Yes
Forced : No
-=Plex Media Info=-
-Media-
Duration 1:56:20
Bitrate 25125 kbps
Width 3840
Height 2076
Aspect Ratio 1.85
Video Resolution 4K
Container MKV
Video Frame Rate 24p
Video Profile main 10
-Part-
Duration 1:56:20
File {filename removed}.mkv
Size 20.42 GB
Container MKV
-Other-
Codec HEVC
Bitrate 24741 kbps
D O V I B L Present true
D O V I Level 6
D O V I Present true
D O V I Profile 5
D O V I R P U Present true
D O V I Version 1.0
Bit Depth 10
Chroma Location left
Chroma Subsampling 4:2:0
Coded Height 2080
Coded Width 3840
Color Range tv
Frame Rate 23.976 fps
Height 2076
Level 5.0
Profile main 10
Ref Frames 1
Width 3840
Display Title 4K DoVi (HEVC Main 10)
Extended Display Title 4K DoVi (HEVC Main 10)
Codec AC3
Channels 6
Bitrate 384 kbps
Language English
Language Tag en
Audio Channel Layout 5.1(side)
Sampling Rate 48000 Hz
Title British
Display Title English (AC3 5.1)
Extended Display Title British (English AC3 5.1)
Codec SRT
Language English
Language Tag en
Title English British (CC)
Display Title English (SRT)
Extended Display Title English British (CC) (SRT)
The following file played without issue.
-=MediaInfo=-
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Duration : 1 h 43 min
Bit rate : 23.6 Mb/s
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.119
Stream size : 17.0 GiB (95%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 295 cd/m2
Maximum Frame-Average Light Level : 99 cd/m2
-=Plex Info=-
Media
Duration 1:43:16
Bitrate 24856 kbps
Width 3840
Height 2160
Aspect Ratio 1.78
Video Resolution 4K
Container MKV
Part
Duration 1:43:16
File {removed}.mkv
Size 17.93 GB
Container MKV
Codec HEVC
Bitrate 24088 kbps
Language English
Language Tag en
D O V I B L Compat I D 1
D O V I Level 6
D O V I Profile 8
D O V I Version 1.0
Bit Depth 10
Chroma Location topleft
Coded Height 2160
Coded Width 3840
Color Primaries bt2020
Color Range tv
Color Space bt2020nc
Color Trc smpte2084
Frame Rate 24 fps
Height 2160
Level 5.0
Original true
Profile main 10
Ref Frames 1
Width 3840
Display Title 4K DoVi/HDR10 (HEVC Main 10)
Extended Display Title (4K DoVi/HDR10 HEVC Main 10)
Codec EAC3
Channels 6
Bitrate 768 kbps
Language English
Language Tag en
Original true
Display Title English (EAC3 5.1)
Extended Display Title (English EAC3 5.1)
Codec SRT
Language English
Language Tag en
Original true
Extended Display Title (English SRT)
Codec SRT
Language English
Language Tag en
Hearing Impaired true
Original true
Title SDH
Display Title English SDH (SRT)
Extended Display Title SDH (English SRT)
Codec SRT
Language Spanish
Language Tag es
Dub true
Title Latin American
Display Title Spanish (SRT)
Extended Display Title Latin American (Spanish SRT)
Codec SRT
Language French
Language Tag fr
Dub true
Title Canadian
Display Title French (SRT)
Extended Display Title Canadian (French SRT)
If you search this forum you will find multiple topics about it. In short: The LG TVs can only play Dolby Vision in MP4 files, but not in MKV files. This is a limitation of the TV itself, not of Plex.
So if you want Dolby Vision, you need to remux the file to MP4.
The reason why your second file “works” is that it contains both Dolby Vision and HDR10 data. You can see this in the “HDR format” line of MediaInfo. In that case Plex will just play the HDR10 version.
Thank you so much. I now have an automated script that will convert DV files to mp4 using ffmpeg.
Do you know if there is information on TVs that will play DV MKV files?
No idea, sorry.
