Server Version#: 4.108.0
Player Version#: 9.25.0.2374
I have one library of content that relies on folder view, and it’s got a lot of folders (approximately 725). The UI in the Android client seems to not handle this the best. If I start from the top and slowly scroll down, waiting for things to load as I go, things are usually fine. But if I know the actress’ name starts with say an M and I scroll quickly to the middle of the list, I often get these grey boxes where a folder would be. Not only can I not click it, I cant click surrounding folders, either. I have to scroll down (or up) a ways, let it load in some more folders, then go back, and try to open the folder that I want. Sometimes I have to do that a couple of times for it to work. Screenshot attached.
I’ve considered moving these all to collections instead of folders, but creating folders is easier to do. I also have not tried 700+ collections at a time, so I dont know if that would have similar issues to what I’m dealing with using folders.
Thoughts or suggestions appreciated.
