Bleach one piece / hunter x hunter / naruto naruto shippuden as soon as plex tv deals with large numbers animes : i get troumendous issues : erratic seasons / episodes / with false sychronisation
plex tv detects 100 episodes over the 366 that Bleach has
if only we could sync with wikipedia api or my anime list api or anidb api with plextv /// what can i do ?
Regards
- Look up your show on TheTVDB
- Take the title as it is used on TheTVDB. If there is something in parentheses, take that too. If the title contains invalid characters (depends on your file system), like
§ : % *, simply leave them out.
- Check the naming and the folder structure of your show. Name the top folder of the show exactly after the title on TheTVDB. No abbreviations. No additional subfolders. No aliases. Add the (year) in parentheses when episode 1 of season 1 of this show was aired.
- Name the episode files according to the above linked naming guide. Use the same title as for the top folder.
Show's Title - s01e01 - additional info.ext (’- additional info’ can be left out)
- After you corrected the naming and folder structure, perform the Plex Dance with all files for this show.
Additional explanation: TheTVDB handles Anime differently than most anime databases.
For instance it will collect all series which belong together under one top category. Sometimes the episode and season subdivision is completely different.
See http://thexem.de/ for some examples.
If you insist on using your current season and epsiode numbering, you need unsupported, 3rd party scanners and agents.
