Here is a screenshot of my albums from the group Boston:
Here you can see that there are two copies of the album Boston and three copies of the album Don’t Look Back. The Boston album I have 2 versions of, one from 1986 and the other is the 2006 remaster. Don’t Look Back, I have the 1986 CD release, the 1982 Japanese CD release, and the 2006 remaster.
My library is set to use tags, and all the dates are tagged properly in the tags, so the dates should be correct.
Make sure that the embedded meta tags (esp. AlbumTitle) of your files are actually different for the two versions of the album.
AlbumArtist must be present
After you corrected metatags and file and folders, perform the Plex Dance (for music you can omit step 4)
Only add one version of an album into Plex at once.
@apastuszak said:
I really don’t want the album title to be different. I tag everything using beets.
AlbumTitle must be different. Otherwise how should Plex know to keep the files apart and show you 2 albums instead of one?
Append something to the original album title, like ‘Album Title - Super Duper Special edition’
That way you’ll still recognise the album but it is different enough so it doesn’t merge into the original album release.
