I am contacting you directly as the bot is confused and asks me to do the same thing again and again.
I have been reading through posts to see why I cannot connect my Plex on my Synology NAS, but all the replies are missing, why?
Why does the Plex system force me into using a specific private IP block? I am using 179.101.x.x behind my router, but I have been told that this will not work, why?
Even when I log on to my Plex account, it shows me my NAS IP address and tells me that it is not currently connected, then I get the No Soup for You message.
What is the difference between ‘nearby’ and ‘remote’ status and does this have any effect with the quality settings when streaming locally or remotely? I set the quality over the internet to 2Mbps, I don’t want to loss quality even though I am on the local network.
I connected the NAS directly in to the modem (10.x.x.x) and I was able to adopt it, the Plex system stated ‘nearby’. I then plugged it back on my network and it then state, ‘remote’, even though it was still local on my network.
Is there a guide on how to set up a Plex server on the Synology NAS, I can’t find it.
Because anything outside of standard
RFC1918 compliant private IP will get DNS confused. Anything outside of that can be owned and in use by a real business DNS may redirect to
nearby = local (same subnet) “Home streaming”
Remote = not local, not same subnet “remote streaming”
