Issues with the "Plex Movie" Agent in retrieving metadatas
I think you are mixing up what a “library” is.
In Plex you cannot have movies and tv shows within the same library.
A “library” in Plex is what appears at the left side of the web app.
There can be libraries of the types
  • movie
  • tv show
  • photo
  • music
Most Plex server platforms allow the creation of several libraries of each type.
Sorry if my terminology was wrong. My left hand side shows the libraries accordingly. So under Animations, all animations are saved there and all TV Shows are saved under TV Programmes. I am sure I got this right when I was reading the Plex forums.
If there is a library scan going on, you can stop it just as you started it: by clicking on the ellipsis, left of the library’s title.
cancel_library_update
However, a Match or a metadata download cannot be aborted. You have to wait for it to finish.
Ok that means a match cannot be stopped. I have a match started for 24 but no ability to cancel.
Yes, you will have to wait. 204 episodes may take a while, particularly on slower NAS devices.
Just confirm my libraries are set up correctly?
I cannot tell whether they are set up correctly. I only see a list of library names on your screen shots.
If you are adhering to the guidelines which are put down here, you should be good:
https://support.plex.tv/articles/categories/your-media/
@OttoKerner thank you for your time and assistance. I realised that my NAS may not be suitable to power the Plex. Whenever it scans, the NAS is not very responsive. And the continuous scan previously may have been a glitch somewhere. I might buy an android box to use the Plex, which is great by the way. Just sad that the NAS is not up to the task.
