The remote player closed the connection.
Are you sure there’s enough bandwidth?
You’re sending ok.
Oct 21, 2021 02:37:04.096 [0x7f9b1af10b38] DEBUG - Request: [192.168.1.55:51164 (Subnet)] GET /status/sessions (23 live) TLS GZIP Signed-in Token (MrPl3x)
Oct 21, 2021 02:37:04.096 [0x7f9b1af10b38] DEBUG - [Now] Adding 1 sessions.
Oct 21, 2021 02:37:04.096 [0x7f9b1af10b38] WARN - Caught exception trying to convert extra data attribute 'originallyAvailableAt' with type 1 and value '2018-11-02' ~ bad lexical cast: source type value could not be interpreted as target
Oct 21, 2021 02:37:04.096 [0x7f9b1cac1b38] DEBUG - Completed: [192.168.1.55:65369] 200 GET /status/sessions (23 live) TLS GZIP 1ms 3776 bytes (pipelined: 1)
Oct 21, 2021 02:37:04.098 [0x7f9b1cac1b38] DEBUG - Completed: [192.168.1.55:51164] 200 GET /status/sessions (23 live) TLS GZIP 2ms 3901 bytes (pipelined: 1)
Oct 21, 2021 02:37:04.147 [0x7f9b1b076b38] DEBUG - Activity: registered new activity 005e2c05-8be4-425b-967c-a8016a2a25b3 - "Cleaning Bundles"
Oct 21, 2021 02:37:04.148 [0x7f9b1b076b38] DEBUG - Activity: updated activity 005e2c05-8be4-425b-967c-a8016a2a25b3 - completed -1.0% - Cleaning Bundles
Oct 21, 2021 02:37:04.362 [0x7f9b1b73db38] DEBUG - [Transcode] Transcoder segment range: 0 - 0 (0)
Oct 21, 2021 02:37:04.389 [0x7f9b1addeb38] DEBUG - Content-Length is -1 (of total: -1).
Oct 21, 2021 02:37:04.389 [0x7f9b1b401b38] DEBUG - [TranscodeOutputStream] Input processing thread started at offset 0 for -1 bytes.
Oct 21, 2021 02:37:04.389 [0x7f9b1b401b38] DEBUG - [TranscodeOutputStream] Changed instance plex-transcode-cprhmeanzi307ldij98x82w5-ae82cedd-589c-4406-8441-9f4edcf0da6e which had to -1; was at chunk -1 with offset -1.000000 now at chunk -1
Oct 21, 2021 02:37:04.538 [0x7f9b1ddb3b38] DEBUG - [Transcode] Transcoder segment range: 0 - 1 (1)
Oct 21, 2021 02:37:04.712 [0x7f9b1a133b38] DEBUG - [Transcode] Transcoder segment range: 0 - 2 (2)
Oct 21, 2021 02:37:04.826 [0x7f9b1deabb38] DEBUG - [Transcode] Transcoder segment range: 0 - 3 (3)
Oct 21, 2021 02:37:04.943 [0x7f9b1a2b0b38] DEBUG - [Transcode] Transcoder segment range: 0 - 4 (4)
Oct 21, 2021 02:37:05.069 [0x7f9b1a2dbb38] DEBUG - [Transcode] Transcoder segment range: 0 - 5 (5)
Oct 21, 2021 02:37:05.184 [0x7f9b1b73db38] DEBUG - [Transcode] Transcoder segment range: 0 - 6 (6)
Oct 21, 2021 02:37:05.303 [0x7f9b1addeb38] DEBUG - [Transcode] Transcoder segment range: 0 - 7 (7)
Oct 21, 2021 02:37:05.410 [0x7f9b1adbbb38] DEBUG - [Transcode] Transcoder segment range: 0 - 8 (8)
Oct 21, 2021 02:37:05.511 [0x7f9b1cae9b38] DEBUG - [Transcode] Transcoder segment range: 0 - 9 (9)
Oct 21, 2021 02:37:05.623 [0x7f9b1deabb38] DEBUG - [Transcode] Transcoder segment range: 0 - 10 (10)
Oct 21, 2021 02:37:05.637 [0x7f9b1cac1b38] DEBUG - Completed: [192.168.1.55:49828] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (23 live) TLS GZIP 20000ms 5 bytes (pipelined: 20)
Then the player closes the connection on you.
Oct 21, 2021 02:37:40.196 [0x7f9b1af10b38] DEBUG - [Transcode] Transcoder segment range: 0 - 353 (353)
Oct 21, 2021 02:37:40.293 [0x7f9b1addeb38] DEBUG - [Transcode] Transcoder segment range: 0 - 354 (354)
Oct 21, 2021 02:37:40.343 [0x7f9b1cac1b38] DEBUG - WebSocket: client initiated close
Oct 21, 2021 02:37:40.343 [0x7f9b1cac1b38] DEBUG - NotificationStream: Removing because of close
Oct 21, 2021 02:37:40.389 [0x7f9b1cac1b38] DEBUG - handleStreamRead code 1: stream truncated
Oct 21, 2021 02:37:40.389 [0x7f9b1cac1b38] DEBUG - Completed after connection close: [192.168.1.55:63622] -3 GET /:/websockets/notifications?filters=log (17 live) TLS GZIP 238412ms 1215168 bytes
Oct 21, 2021 02:37:40.401 [0x7f9b1adbbb38] DEBUG - [Transcode] Transcoder segment range: 0 - 355 (355)
Oct 21, 2021 02:37:40.494 [0x7f9b1ddb3b38] DEBUG - [Transcode] Transcoder segment range: 0 - 356 (356)
Oct 21, 2021 02:37:40.588 [0x7f9b1a2b0b38] DEBUG - [Transcode] Transcoder segment range: 0 - 357 (357)
Oct 21, 2021 02:37:40.691 [0x7f9b1a2dbb38] DEBUG - [Transcode] Transcoder segment range: 0 - 358 (358)
Oct 21, 2021 02:37:40.787 [0x7f9b1ab49b38] DEBUG - [Transcode] Transcoder segment range: 0 - 359 (359)
Oct 21, 2021 02:37:40.876 [0x7f9b1aac4b38] DEBUG - Request: [192.168.1.234:40308 (Subnet)] GET /:/timeline?key=%2Flibrary%2Fmetadata%2F29648&ratingKey=29648&state=playing&time=395105&duration=5956139&playbackTime=390698&playQueueItemID=1169&context=home%3Ahub.continueWatching&row=0&col=0 (16 live) GZIP Signed-in Token (MrPl3x)
Oct 21, 2021 02:37:40.876 [0x7f9b1aac4b38] DEBUG - Client [ej6dgoyy8uidqqnx7e7yxhzn] reporting timeline state playing, progress of 395105/5956139ms for guid=, playbackTime=390698ms ratingKey=29648 url=, key=/library/metadata/29648, containerKey=, metadataId=29648, source=
Oct 21, 2021 02:37:40.878 [0x7f9b1aac4b38] DEBUG - Play progress on 29648 'The Nutcracker and the Four Realms' - got played 395105 ms by account 1!
Oct 21, 2021 02:37:40.878 [0x7f9b1aac4b38] DEBUG - [Now] User is MrPl3x (ID: 1)
Oct 21, 2021 02:37:40.878 [0x7f9b1aac4b38] DEBUG - [Now] Device is webOS (LG 65NANO90UPA).
Oct 21, 2021 02:37:40.878 [0x7f9b1aac4b38] DEBUG - [Now] Profile is Generic
Oct 21, 2021 02:37:40.878 [0x7f9b1aac4b38] DEBUG - [Now] Updated play state for /library/metadata/29648.
Oct 21, 2021 02:37:40.878 [0x7f9b1aac4b38] DEBUG - Statistics: (ej6dgoyy8uidqqnx7e7yxhzn) Reporting active playback in state 0 of type 1 (scrobble: 0) for account 1
Oct 21, 2021 02:37:40.879 [0x7f9b1ab8fb38] DEBUG - [Transcode] Transcoder segment range: 0 - 360 (360)
Oct 21, 2021 02:37:40.880 [0x7f9b1ca9eb38] DEBUG - Completed: [192.168.1.234:40308] 200 GET /:/timeline?key=%2Flibrary%2Fmetadata%2F29648&ratingKey=29648&state=playing&time=395105&duration=5956139&playbackTime=390698&playQueueItemID=1169&context=home%3Ahub.continueWatching&row=0&col=0 (16 live) GZIP 4ms 886 bytes (pipelined: 5)
Oct 21, 2021 02:37:40.974 [0x7f9b1b73db38] DEBUG - [Transcode] Transcoder segment range: 0 - 361 (361)
Oct 21, 2021 02:37:41.081 [0x7f9b1adbbb38] DEBUG - [Transcode] Transcoder segment range: 0 - 362 (362)
Oct 21, 2021 02:37:41.185 [0x7f9b1cae9b38] DEBUG - [Transcode] Transcoder segment range: 0 - 363 (363)
Oct 21, 2021 02:37:41.284 [0x7f9b1a2b0b38] DEBUG - [Transcode] Transcoder segment range: 0 - 364 (364)
Oct 21, 2021 02:37:41.380 [0x7f9b1ab49b38] DEBUG - [Transcode] Transcoder segment range: 0 - 365 (365)
Oct 21, 2021 02:37:41.473 [0x7f9b1ab8fb38] DEBUG - [Transcode] Transcoder segment range: 0 - 366 (366)
Oct 21, 2021 02:37:41.576 [0x7f9b1aac4b38] DEBUG - [Transcode] Transcoder segment range: 0 - 367 (367)
Oct 21, 2021 02:37:41.662 [0x7f9b1ab6cb38] DEBUG - [Transcode] Transcoder segment range: 0 - 368 (368)
Oct 21, 2021 02:37:41.759 [0x7f9b1ddb3b38] DEBUG - [Transcode] Transcoder segment range: 0 - 369 (369)
Oct 21, 2021 02:37:41.860 [0x7f9b1deabb38] DEBUG - [Transcode] Transcoder segment range: 0 - 370 (370)
Oct 21, 2021 02:37:41.947 [0x7f9b1a133b38] DEBUG - [Transcode] Transcoder segment range: 0 - 371 (371)
Oct 21, 2021 02:37:42.044 [0x7f9b1cae9b38] DEBUG - [Transcode] Transcoder segment range: 0 - 372 (372)
Oct 21, 2021 02:37:42.152 [0x7f9b1ab49b38] DEBUG - [Transcode] Transcoder segment range: 0 - 373 (373)
Oct 21, 2021 02:37:42.215 [0x7f9b1aac4b38] DEBUG - Request: [192.168.1.55:57527 (Subnet)] GET /:/prefs (20 live) TLS GZIP Signed-in Token (MrPl3x)
Oct 21, 2021 02:37:42.215 [0x7f9b1af10b38] DEBUG - Request: [192.168.1.55:59129 (Subnet)] GET /accounts/1 (20 live) TLS GZIP Signed-in Token (MrPl3x)
Oct 21, 2021 02:37:42.216 [0x7f9b1ca9eb38] DEBUG - Completed: [192.168.1.55:59129] 200 GET /accounts/1 (20 live) TLS GZIP 0ms 645 bytes (pipelined: 1)
Oct 21, 2021 02:37:42.217 [0x7f9b1ab6cb38] DEBUG - Request: [192.168.1.55:60156 (Subnet)] GET /myplex/account (20 live) TLS GZIP Signed-in Token (MrPl3x)
Oct 21, 2021 02:37:42.218 [0x7f9b1b73db38] DEBUG - Request: [192.168.1.55:57934 (Subnet)] GET /system/:/prefs (20 live) TLS GZIP Signed-in Token (MrPl3x)
Oct 21, 2021 02:37:42.218 [0x7f9b1b73db38] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /system/:/prefs
Oct 21, 2021 02:37:42.218 [0x7f9b1ca9eb38] DEBUG - Completed: [192.168.1.55:60156] 200 GET /myplex/account (20 live) TLS GZIP 1ms 3641 bytes (pipelined: 1)
Oct 21, 2021 02:37:42.219 [0x7f9b1b73db38] DEBUG - HTTP requesting GET http://127.0.0.1:37145/system/:/prefs
Oct 21, 2021 02:37:42.224 [0x7f9b1ca9eb38] DEBUG - Completed: [192.168.1.55:57527] 200 GET /:/prefs (20 live) TLS GZIP 8ms 8569 bytes (pipelined: 1)
Oct 21, 2021 02:37:42.225 [0x7f9b1b73db38] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://127.0.0.1:37145/system/:/prefs
Oct 21, 2021 02:37:42.225 [0x7f9b1b73db38] DEBUG - [com.plexapp.system] HTTP reply status 200, with 418 bytes of content.
Oct 21, 2021 02:37:42.225 [0x7f9b1ca9eb38] DEBUG - Completed: [192.168.1.55:57934] 200 GET /system/:/prefs (20 live) TLS GZIP 7ms 859 bytes (pipelined: 1)
Oct 21, 2021 02:37:42.259 [0x7f9b1ddb3b38] DEBUG - [Transcode] Transcoder segment range: 0 - 374 (374)
Oct 21, 2021 02:37:42.350 [0x7f9b1deabb38] DEBUG - [Transcode] Transcoder segment range: 0 - 375 (375)
Oct 21, 2021 02:37:42.448 [0x7f9b1a133b38] DEBUG - [Transcode] Transcoder segment range: 0 - 376 (376)
Oct 21, 2021 02:37:42.537 [0x7f9b1cae9b38] DEBUG - Request: [192.168.1.234:40272 (Subnet)] GET /video/:/transcode/universal/session/a38uezwifimweduisqcy0e8h/base/00054.ts (20 live) Signed-in (range: bytes=0-)
Oct 21, 2021 02:37:42.537 [0x7f9b1cae9b38] DEBUG - [Transcode/a38uezwifimweduisqcy0e8h] Asked for segment 54 from session.
Oct 21, 2021 02:37:42.537 [0x7f9b1cae9b38] DEBUG - [Transcode/a38uezwifimweduisqcy0e8h] Returning segment 54 from session
Oct 21, 2021 02:37:42.537 [0x7f9b1cae9b38] DEBUG - Content-Length of /mnt/encoder/Transcode/Sessions/plex-transcode-a38uezwifimweduisqcy0e8h-3ef7c807-aac1-4536-83a2-55b0f7f6d6d5/media-00054.ts is 516436 (of total: 516436).
Oct 21, 2021 02:37:42.539 [0x7f9b1ca9eb38] DEBUG - Completed: [192.168.1.234:40272] 206 GET /video/:/transcode/universal/session/a38uezwifimweduisqcy0e8h/base/00054.ts (20 live) 2ms 516436 bytes (pipelined: 55) (range: bytes=0-)
Oct 21, 2021 02:37:42.539 [0x7f9b1ca9eb38] DEBUG - Removed transcode data consumer, active count 1 => 0
Oct 21, 2021 02:37:42.541 [0x7f9b1a2b0b38] DEBUG - [Transcode] Transcoder segment range: 0 - 377 (377)
Oct 21, 2021 02:37:42.596 [0x7f9b1a2dbb38] DEBUG - [Transcode] Session a38uezwifimweduisqcy0e8h (3) is unthrottling
Oct 21, 2021 02:37:42.597 [0x7f9b1b71ab38] DEBUG - [Transcoder] Throttle - Getting back to work.
Oct 21, 2021 02:37:42.635 [0x7f9b1ab49b38] DEBUG - [Transcode] Transcoder segment range: 0 - 378 (378)
Oct 21, 2021 02:37:42.751 [0x7f9b1addeb38] DEBUG - [Transcode] Transcoder segment range: 0 - 379 (379)
Oct 21, 2021 02:37:42.869 [0x7f9b1aac4b38] DEBUG - [Transcode] Transcoder segment range: 0 - 380 (380)
Oct 21, 2021 02:37:42.988 [0x7f9b1adbbb38] DEBUG - [Transcode] Transcoder segment range: 0 - 381 (381)
Oct 21, 2021 02:37:43.006 [0x7f9b1ddb3b38] DEBUG - [Transcode] Transcoder segment range: 0 - 92 (92)
Oct 21, 2021 02:37:43.006 [0x7f9b1deabb38] DEBUG - [Transcode] Transcoder segment range: 0 - 93 (92)
Oct 21, 2021 02:37:43.094 [0x7f9b1a133b38] DEBUG - [Transcode] Transcoder segment range: 0 - 382 (382)
Oct 21, 2021 02:37:43.201 [0x7f9b1b71ab38] DEBUG - [Transcode] Transcoder segment range: 0 - 383 (383)
Oct 21, 2021 02:37:43.317 [0x7f9b1ab49b38] DEBUG - [Transcode] Transcoder segment range: 0 - 384 (384)
Oct 21, 2021 02:37:43.437 [0x7f9b1ab8fb38] DEBUG - [Transcode] Transcoder segment range: 0 - 385 (385)
Oct 21, 2021 02:37:43.500 [0x7f9b1af10b38] DEBUG - [Transcode] Session a38uezwifimweduisqcy0e8h (3) is throttling
Oct 21, 2021 02:37:43.500 [0x7f9b1ab6cb38] DEBUG - [Transcoder] Throttle - Going into sloth mode.
Oct 21, 2021 02:37:43.536 [0x7f9b1addeb38] DEBUG - [Transcode] Transcoder segment range: 0 - 386 (386)
Oct 21, 2021 02:37:43.640 [0x7f9b1aac4b38] DEBUG - [Transcode] Transcoder segment range: 0 - 387 (387)
Oct 21, 2021 02:37:43.749 [0x7f9b1deabb38] DEBUG - [Transcode] Transcoder segment range: 0 - 388 (388)
Oct 21, 2021 02:37:43.849 [0x7f9b1a133b38] DEBUG - [Transcode] Transcoder segment range: 0 - 389 (389)
Oct 21, 2021 02:37:43.855 [0x7f9b1cae9b38] DEBUG - Request: [192.168.1.55:63830 (Subnet)] GET /diagnostics/logs (21 live) TLS GZIP Signed-in Token (MrPl3x)
Plenty were both on fiber and it should be transcoding down to 8mbit to 14mbit
LG 65NANO90UPA). is my tv
I don’t know what to tell you.
I can see the server is ok.
It’s doing what it should.
How about uninstalling then reinstalling the player app on the TV?
That’s all I can think of (I’m not player guy)
Ill give it a go, But as for the second mystery GPU? Could that pose an issue?
Only if the drivers aren’t current.
Ok ill keep at it
Yes, that could be it.
You want Nvidia’s driverrs to be in control with (i presume) nothing else attached to it unless you’re using nouveau as the GUI destkop driver
Where’s the HDMI cable connected for display? Mobo or Nvidia?
Nothing is connected to the server and Nvidia GPU is in second slot because ram is in the way of first slot.
nouveau is blacklisted
no desktop bare min install
GPU is in yellow highlighted area
Which model? I have the X10SRA-F-O
Which kernel is running?
https://www.supermicro.com/products/motherboard/Xeon/C600/X9DRi-F.cfm
Linux gentoo 5.10.68-gentoo-dist #1 SMP Wed Sep 22 14:33:48 -00 2021 x86_64 Intel(R) Xeon(R) CPU E5-2630L v2 @ 2.40GHz GenuineIntel GNU/Linux
How difficult would it be to:
- Make a ubuntu server 20.04.3 boot usb
- Put a HDD in an enclosure
- plug both USBs in
- Boot and install Ubuntu server to the USB drive
- Add a test plex and Nvidia drivers.
I suggest this because:
- I know ubuntu server works.
- I don’t know how Gentoo is .
- I do know Gentoo, for the large part, is an OS you configure and compile yourself.
There seem to be a lot of potential variables in flight and Ubuntu Server would eliminate the vast majority of them
superplex@superduperplex:~$ uname -a
Linux superduperplex 5.11.0-38-generic #42-Ubuntu SMP Fri Sep 24 14:03:54 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Get that on all media
