I am running my tv shows using a tv shows library and have the file structure and name as adviced by Plex.tv. (eg Prison Break > Season 01 > Prison Break - s01e01.mkv). For some reason I am unable to get the meta data (episode title, summary info, correct posters) to pull through. Instead I typically get a non-descriptive “Episode 1”. The media plays just fine, but I would love to have the metadata pull through for organizational sake. Thanks for the feedback.
What platform is the server running on?
Does your router have IPv6 support? Disable it for a while.
Running the server on a Synology DS418play. IPV6 is disabled.
On the router?
in Plex?
or in the system settings of your NAS?
I checked it off on the router. Should I try on the other locations? I am not sure what this setting has to do with the metadata since it works perfectly with movies and other media. Thanks for your help.
Please post the content of the Plex XML info of one episode.
<MediaContainer size=“1” allowSync=“1” identifier=“com.plexapp.plugins.library” librarySectionID=“4” librarySectionTitle=“TV Shows” librarySectionUUID=“63ed66bc-5eb2-4243-97d3-6da56a85e0b0"mediaTagPrefix=”/system/bundle/media/flags/" mediaTagVersion=“1544817990”>
<Video ratingKey=“7804” key="/library/metadata/7804" parentRatingKey=“7803” grandparentRatingKey=“3438” guid=“local://7804” librarySectionTitle=“TV Shows” librarySectionID=“4"librarySectionKey=”/library/sections/4" type=“episode” title=“Episode 1” grandparentKey="/library/metadata/3438" parentKey="/library/metadata/7803" grandparentTitle=“Prison Break” parentTitle=“Season 2"contentRating=“TV-14” summary=”" index=“1” parentIndex=“2” viewCount=“1” lastViewedAt=“1550331713” thumb="/library/metadata/7804/thumb/1550184502" art="/library/metadata/3438/art/1550218735"grandparentThumb="/library/metadata/3438/thumb/1550218735" grandparentArt="/library/metadata/3438/art/1550218735" grandparentTheme="/library/metadata/3438/theme/1550218735" duration="2385480"addedAt=“1550184481” updatedAt=“1550184502” chapterSource=“media”>
<Media videoResolution=“576” id=“11736” duration=“2385480” bitrate=“5294” width=“720” height=“576” aspectRatio=“1.78” audioChannels=“6” audioCodec=“ac3” videoCodec=“mpeg2video” container="mkv"videoFrameRate=“PAL” videoProfile=“main”>
<Part accessible=“1” exists=“1” id=“11913” key="/library/parts/11913/1549657158/file.mkv" duration=“2385480” file="/volume1/video/tv shows/Prison Break/Seaon 02/Prison Break s02e01.mkv" size="1578630611"container=“mkv” deepAnalysisVersion=“2” requiredBandwidths=“6680,6256,5567,5438,5438,5438,5438,5438” videoProfile=“main”>
<Stream id=“28530” streamType=“1” codec=“mpeg2video” index=“0” bitrate=“4654” language=“English” languageCode=“eng” anamorphic=“1” bitDepth=“8” chromaLocation=“left” chromaSubsampling="4:2:0"colorRange=“tv” frameRate=“25.000” height=“576” level=“8” pixelAspectRatio=“64:45” profile=“main” refFrames=“1” requiredBandwidths=“6024,5599,4912,4785,4785,4785,4785,4785” scanType=“interlaced” width="720"displayTitle=“480i (MPEG2VIDEO)”/>
<Stream id=“28531” streamType=“2” selected=“1” default=“1” codec=“ac3” index=“1” channels=“6” bitrate=“448” language=“English” languageCode=“eng” audioChannelLayout="5.1(side)"requiredBandwidths=“448,448,448,448,448,448,448,448” samplingRate=“48000” title=“Surround 5.1” displayTitle=“English (AC3 5.1)”/>
<Stream id=“28532” streamType=“2” codec=“ac3” index=“2” channels=“2” bitrate=“192” language=“English” languageCode=“eng” audioChannelLayout=“stereo” requiredBandwidths="192,192,192,192,192,192,192,192"samplingRate=“48000” title=“Stereo” displayTitle=“English (AC3 Stereo)”/>
Should be: (spelling error)
Prison Break/Season 02/Prison Break - s02e01.mkv
Aww. I can’t believe I missed that in plain site. I made the changes, but still having the same issue. Here is the updated xml.
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<Video ratingKey=“7804” key="/library/metadata/7804" parentRatingKey=“7803” grandparentRatingKey=“3438” guid=“local://7804” librarySectionTitle=“TV Shows” librarySectionID=“4"librarySectionKey=”/library/sections/4" type=“episode” title=“Episode 1” grandparentKey="/library/metadata/3438" parentKey="/library/metadata/7803" grandparentTitle=“Prison Break” parentTitle=“Season 2"contentRating=“TV-14” summary=”" index=“1” parentIndex=“2” viewCount=“1” lastViewedAt=“1550331713” thumb="/library/metadata/7804/thumb/1550361968" art="/library/metadata/3438/art/1550218735"grandparentThumb="/library/metadata/3438/thumb/1550218735" grandparentArt="/library/metadata/3438/art/1550218735" grandparentTheme="/library/metadata/3438/theme/1550218735" duration="2385480"addedAt=“1550184481” updatedAt=“1550361968” chapterSource=“media”>
<Part accessible=“1” exists=“1” id=“12077” key="/library/parts/12077/1549657158/file.mkv" duration=“2385480” file="/volume1/video/tv shows/Prison Break/Season 02/Prison Break - s02e01.mkv" size="1578630611"container=“mkv” videoProfile=“main”>
<Stream id=“29175” streamType=“1” codec=“mpeg2video” index=“0” bitrate=“4654” language=“English” languageCode=“eng” anamorphic=“1” bitDepth=“8” chromaLocation=“left” chromaSubsampling="4:2:0"colorRange=“tv” frameRate=“25.000” height=“576” level=“8” pixelAspectRatio=“64:45” profile=“main” refFrames=“1” scanType=“interlaced” width=“720” displayTitle=“480i (MPEG2VIDEO)”/>
<Stream id=“29176” streamType=“2” selected=“1” default=“1” codec=“ac3” index=“1” channels=“6” bitrate=“448” language=“English” languageCode=“eng” audioChannelLayout=“5.1(side)” samplingRate="48000"title=“Surround 5.1” displayTitle=“English (AC3 5.1)”/>
That was the fix!! Thank you thank you so much!
