Server Version#: 1.18.2.2029
I have just added a new Seedbox which is running Plex.
I have a folder called TV Shows 4K, which has 17 shows in it (all correctly set up).
Plex only seems to be grabbing Metadata from 2 of the Shows Rssian Doll & Pwers (2015). Nothing is downloaded for the other 15 shows.
I would add that Plex grabs metadata fine on my other Seedboxes with the exact same content (all on a gSuite drive) and also with the same shows on my local NAS.
Also, Plex also grabs metadata fine for my Movies 4K folder on this new seedbox, just not the TV Shows 4K folder.
So far, I have:
Uninstalled/reinstalled Plex a few times,
Upgraded to 1.18.2.2029
Plex Dance
Attempted Scan Library, Refresh all metadata, attempted refresh metadata on individual TV Shows, Fix match, Unmatch, Match on individual TV Shows.
Log:
Nov 15, 2019 09:50:47.002 [0x7f7f2fa69700] INFO - Plex Media Server v1.18.2.2029-36236cc4c - Docker Docker Container (LinuxServer.io) x86_64 - build: linux-x86_64 debian - GMT 00:00
Nov 15, 2019 09:50:47.002 [0x7f7f2fa69700] INFO - Linux version: 4.19.76-xanmod37, language: en-US
Nov 15, 2019 09:50:47.002 [0x7f7f2fa69700] INFO - Processor Intel® Xeon® CPU E5-2699 v3 @ 2.30GHz
Nov 15, 2019 09:50:47.002 [0x7f7f2fa69700] INFO - /usr/lib/plexmediaserver/Plex Media Server
Nov 15, 2019 09:50:47.021 [0x7f7f39972b80] INFO - SQLITE3:(nil), 283, recovered 481 frames from WAL file /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Nov 15, 2019 09:50:47.067 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.069 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.071 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.072 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.074 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.076 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.078 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.079 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.081 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.082 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.084 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.086 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.087 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.089 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.091 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.092 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.094 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.096 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.097 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.103 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.105 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.106 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.108 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.110 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.111 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.113 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.114 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.116 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.118 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.119 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.121 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.123 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.124 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.126 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.127 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.129 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.131 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.132 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.290 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.292 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.294 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.295 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.297 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.299 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.301 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.302 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.304 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.306 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.307 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.309 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.311 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.312 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.314 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.316 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.317 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.319 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.321 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.488 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.490 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.492 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.493 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.495 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.497 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.498 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.500 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.502 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.503 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.505 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.507 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.508 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.510 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.511 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.513 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.515 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.516 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.518 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.618 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.622 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.645 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.668 [0x7f7f39972b80] INFO - SQLITE3:(nil), 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 15, 2019 09:50:47.671 [0x7f7f2ea67700] INFO - CodecManager: obtaining decoder ‘vp9’
Nov 15, 2019 09:50:47.707 [0x7f7f39972b80] INFO - OCSP: Successfully retrieved response from cache.
Nov 15, 2019 09:50:47.970 [0x7f7f2ea67700] INFO - CodecManager: obtaining decoder ‘hevc’
Nov 15, 2019 09:50:48.386 [0x7f7f2ea67700] INFO - CodecManager: obtaining decoder ‘h264’
Nov 15, 2019 09:50:50.569 [0x7f7f39972b80] ERROR - Transcoder: Error cleaning old transcode sessions: boost::filesystem::directory_iterator::construct: No such file or directory: “/transcode/Transcode/Sessions”
Nov 15, 2019 09:50:50.597 [0x7f7ed6ffd700] WARN - Request for plug-in [org.musicbrainz.agents.music] but it doesn’t exist.
Nov 15, 2019 09:50:50.678 [0x7f7ed6ffd700] WARN - Request for plug-in [tv.plex.agents.music] but it doesn’t exist.
Nov 15, 2019 09:50:51.250 [0x7f7efffff700] INFO - Sync: downloaded 0 sync list(s) with 0 sync items(s): 0 new, 0 updated, 0 deleted
Nov 15, 2019 09:50:51.250 [0x7f7ebeffd700] WARN - Sync: local sync directory “/config/Library/Application Support/Plex Media Server/Cache/Transcode/Sync+” does not exist
Nov 15, 2019 09:50:53.617 [0x7f7f2f268700] WARN - JobManager: Could not find job for handle 526
Nov 15, 2019 09:50:53.641 [0x7f7f2f268700] WARN - JobManager: Could not find job for handle 531
Nov 15, 2019 09:50:54.724 [0x7f7f2f268700] WARN - JobManager: Could not find job for handle 592
Nov 15, 2019 09:50:55.427 [0x7f7f2f268700] WARN - JobManager: Could not find job for handle 444
Nov 15, 2019 09:50:55.794 [0x7f7ed67fc700] INFO - AutoUpdate: no updates available
Nov 15, 2019 09:50:55.892 [0x7f7f2f268700] WARN - JobManager: Could not find job for handle 630
Nov 15, 2019 09:50:56.961 [0x7f7f2f268700] WARN - JobManager: Could not find job for handle 641
Nov 15, 2019 09:50:59.244 [0x7f7f2f268700] WARN - JobManager: Could not find job for handle 698
Nov 15, 2019 09:50:59.513 [0x7f7efe7fc700] INFO - AutoUpdate: no updates available
Nov 15, 2019 09:50:59.905 [0x7f7f1effd700] WARN - NAT: PMP, got an error: Not Supported by gateway.
Nov 15, 2019 09:50:59.928 [0x7f7efe7fc700] INFO - AutoUpdate: no updates available
Nov 15, 2019 09:51:01.369 [0x7f7f2f268700] WARN - JobManager: Could not find job for handle 734
Nov 15, 2019 09:51:01.919 [0x7f7ebeffd700] ERROR - Unknown metadata type:
Nov 15, 2019 09:51:02.455 [0x7f7f1dffb700] INFO - LibraryUpdateManager path watching is disabled
Nov 15, 2019 09:51:02.459 [0x7f7f2f268700] WARN - JobManager: Could not find job for handle 661
Nov 15, 2019 09:51:06.671 [0x7f7e7affd700] ERROR - Error issuing curl_easy_perform(handle): 28
Nov 15, 2019 09:52:55.140 [0x7f7ed7fff700] WARN - QueryParser: Invalid field ‘onlyTransient’ found, ignoring.
Nov 15, 2019 09:52:55.144 [0x7f7ed7fff700] WARN - QueryParser: Invalid field ‘onlyTransient’ found, ignoring.
Nov 15, 2019 09:52:55.338 [0x7f7ed6ffd700] INFO - AutoUpdate: no updates available
Nov 15, 2019 09:52:57.822 [0x7f7efeffd700] ERROR - Unknown metadata type: folder
Nov 15, 2019 09:53:07.314 [0x7f7ed5ffb700] WARN - QueryParser: Invalid field ‘sectionID’ found, ignoring.
Nov 15, 2019 09:53:07.322 [0x7f7ed5ffb700] WARN - QueryParser: Invalid field ‘sectionID’ found, ignoring.
Nov 15, 2019 09:53:07.356 [0x7f7efeffd700] ERROR - Unknown metadata type: folder
Nov 15, 2019 09:53:08.005 [0x7f7e657fa700] WARN - QueryParser: Invalid field ‘sectionID’ found, ignoring.
Nov 15, 2019 09:53:08.014 [0x7f7e657fa700] WARN - QueryParser: Invalid field ‘sectionID’ found, ignoring.
Nov 15, 2019 09:53:08.020 [0x7f7e5bfff700] ERROR - Unknown metadata type: folder
Nov 15, 2019 09:53:14.917 [0x7f7f2f268700] WARN - JobManager: Could not find job for handle 441
Nov 15, 2019 09:53:17.776 [0x7f7f2f268700] WARN - JobManager: Could not find job for handle 447
