Jobs: Exec of ./CrashUploader failed. (2)
Server Version#:1.29.1.6316-f4cdfea9c
suddenly saw it…do i need to worry?)))
sid@kino:~$ splex
● plexmediaserver.service - Plex Media Server
     Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; preset: enabled)
     Active: active (running) since Thu 2022-10-20 11:06:15 MSK; 1 day 6h ago
   Main PID: 992966 (Plex Media Serv)
      Tasks: 149 (limit: 6930)
     Memory: 313.9M
        CPU: 47min 34.711s
     CGroup: /system.slice/plexmediaserver.service
             ├─ 992966 "/usr/lib/plexmediaserver/Plex Media Server"
             ├─ 992990 "Plex Plug-in [com.plexapp.system]" /usr/lib/plexmediaserver/Resources/Plug-ins-f4cdfea9c/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.29.1.6316-f4cdfea9c /usr/lib/ple>
             ├─ 993033 "/usr/lib/plexmediaserver/Plex DLNA Server"
             ├─ 993035 "/usr/lib/plexmediaserver/Plex Tuner Service" /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1.29.1.6316-f4cdfea9c 32600
             ├─ 993063 "Plex Plug-in [tv.plex.agents.movie]" /usr/lib/plexmediaserver/Resources/Plug-ins-f4cdfea9c/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.29.1.6316-f4cdfea9c /usr/lib/p>
             ├─ 993181 "Plex Plug-in [com.plexapp.agents.thetvdb]" /usr/lib/plexmediaserver/Resources/Plug-ins-f4cdfea9c/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.29.1.6316-f4cdfea9c /usr>
             ├─ 993196 "Plex Plug-in [org.musicbrainz.agents.music]" /usr/lib/plexmediaserver/Resources/Plug-ins-f4cdfea9c/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.29.1.6316-f4cdfea9c /u>
             ├─ 993227 "Plex Plug-in [com.plexapp.agents.opensubtitles]" /usr/lib/plexmediaserver/Resources/Plug-ins-f4cdfea9c/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.29.1.6316-f4cdfea9>
             ├─ 993245 "Plex Plug-in [tv.plex.agents.series]" /usr/lib/plexmediaserver/Resources/Plug-ins-f4cdfea9c/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.29.1.6316-f4cdfea9c /usr/lib/>
             ├─ 993262 "Plex Plug-in [com.plexapp.agents.kinopoisk2]" /usr/lib/plexmediaserver/Resources/Plug-ins-f4cdfea9c/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.29.1.6316-f4cdfea9c ">
             └─1086797 "/usr/lib/plexmediaserver/Plex Transcoder" -codec:0 mpeg4 -hwaccel:0 vaapi -hwaccel_fallback_threshold:0 10 -hwaccel_output_format:0 vaapi -hwaccel_device:0 vaapi -codec:#0x01 ac3 -analyzeduration 20000000 -p>
Oct 20 11:06:18 kino Plex Media Server[993096]:   --device arg          Device string
Oct 20 11:06:18 kino Plex Media Server[993096]:   --model arg           Device model string
Oct 20 11:06:18 kino Plex Media Server[993096]:   --sentryUrl arg       Sentry URL to upload to
Oct 20 11:06:18 kino Plex Media Server[993096]:   --sentryKey arg       Sentry Key for the project
Oct 20 11:06:18 kino Plex Media Server[993096]:   --version arg         Version of the product
Oct 20 11:06:18 kino Plex Media Server[993096]:   --allowRetries arg    Whether we will allow retries
Oct 20 11:06:19 kino Plex Media Server[993187]: Jobs: Exec of ./CrashUploader failed. (2)
Oct 20 11:06:22 kino Plex Media Server[993262]: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/Kinopoisk.bundle/Contents/Libraries/Shared/fuzzywuzzy/fuzz.py:11: UserWarning: Using slow pure-python S>
Oct 20 11:06:22 kino Plex Media Server[993262]:   warnings.warn('Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning')
Oct 21 11:06:23 kino Plex Media Server[1066571]: The '--scan' operation is deprecated and will be removed in future versions of Plex Media Server.
sid@kino:~$
sid@kino:~$ ll /usr/lib/plexmediaserver/
total 34704
drwxr-xr-x   5 root root     4096 Oct 20 11:05  .
drwxr-xr-x 117 root root     4096 Oct 17 15:14  ..
-rwxr-xr-x   1 root root  1263248 Oct 19 17:48  CrashUploader
drwxr-xr-x   2 root root     4096 Oct 20 11:05  etc
drwxr-xr-x   3 root root    12288 Oct 20 11:05  lib
-rwxr-xr-x   1 root root   271024 Oct 19 17:14 'Plex Commercial Skipper'
-rwxr-xr-x   1 root root  3144496 Oct 19 17:44 'Plex DLNA Server'
-rwxr-xr-x   1 root root   114168 Oct 19 17:14 'Plex Media Fingerprinter'
-rwxr-xr-x   1 root root  4609904 Oct 19 17:49 'Plex Media Scanner'
-rwxr-xr-x   1 root root 19227664 Oct 19 17:56 'Plex Media Server'
-rwxr-xr-x   1 root root  3408944 Oct 19 17:14 'Plex Relay'
-rwxr-xr-x   1 root root    10888 Oct 19 17:14 'Plex Script Host'
-rwxr-xr-x   1 root root    10864 Oct 19 17:14 'Plex SQLite'
-rwxr-xr-x   1 root root   322920 Oct 19 17:14 'Plex Transcoder'
-rwxr-xr-x   1 root root  3092664 Oct 19 17:14 'Plex Tuner Service'
drwxr-xr-x  10 root root    12288 Oct 20 11:05  Resources
sid@kino:~$
but todat is 21… why it keep showing ‘failed’
sid@kino:~$ ll /var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Crash\ Reports/1.29.1.6316-f4cdfea9c
total 24
drwxr-xr-x  6 plex plex 4096 Oct 20 17:40  .
drwxr-xr-x 82 plex plex 4096 Oct 20 11:05  ..
drwxr-xr-x  2 plex plex 4096 Oct 20 11:05 'PLEX DLNA SERVER'
drwxr-xr-x  2 plex plex 4096 Oct 20 17:40 'PLEX MEDIA SCANNER'
drwxr-xr-x  2 plex plex 4096 Oct 20 11:05 'PLEX MEDIA SERVER'
drwxr-xr-x  2 plex plex 4096 Oct 20 11:05 'PLEX TUNER SERVICE'
sid@kino:~$
sid@kino:~$
If Linux can’t start a process (CrashUploader) then there is something going on.
Have you tried a system restart?
Is the root filesystem full ?
yes, i’ve tried restart.
and disk is not full
sid@kino:~$ df -h
Filesystem      Size  Used Avail Use% Mounted on
udev            2.9G     0  2.9G   0% /dev
tmpfs           583M  3.5M  580M   1% /run
/dev/sda1       109G   18G   85G  18% /
tmpfs           2.9G  4.0K  2.9G   1% /dev/shm
tmpfs           5.0M     0  5.0M   0% /run/lock
/dev/sdb5       1.8T  1.4T  311G  83% /mnt/sids
tmpfs           583M   12K  583M   1% /run/user/1000
sid@kino:~$
Distro and version please?
Also, given Linux doesn’t erase your data, have you done an Uninstall/Re-install cycle?
PS: I’m seeing other reports of this failure. Investigating now.
Can you also please see what dmesg reports and include the Plex logs ?
Just to add, upgraded the official docker to 1.29.1.6316 and see the same error message in the unRAID logs:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 40-plex-first-run: executing...
Plex Media Server first run setup complete
[cont-init.d] 40-plex-first-run: exited 0.
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: executing...
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: exited 0.
[cont-init.d] 50-plex-update: executing...
[cont-init.d] 50-plex-update: exited 0.
[cont-init.d] done.
[services.d] starting services
Starting Plex Media Server.
[services.d] done.
Critical: libusb_init failed
logs:
Oct 21, 2022 22:50:01.347 [0x14c9c0c9fb38] DEBUG - [JobRunner] Job running: /usr/lib/plexmediaserver/CrashUploader "--directory=/config/Library/Application Support/Plex Media Server/Crash Reports/1.29.1.6316-f4cdfea9c" --version=1.29.1.6316-f4cdfea9c --platform=Linux --platformVersion=5.15.46-Unraid --serverUuid=7b85813c028259affadd583b2de1adafa1ce2157 --userId=XXXXXXXXXXXX --sentryUrl=https://sentry.io/api/1233455/minidump --sentryKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx --vendor=Docker --model=x86_64 "--device=Docker Container" --allowRetries=0
Oct 21, 2022 22:50:01.347 [0x14c9c0c9fb38] DEBUG - [JobRunner] Jobs: Starting child process with pid 371
Oct 21, 2022 22:50:01.392 [0x14c9c108cb38] DEBUG - [HttpClient/HCl#19] HTTP/2.0 (0.1s) 200 response from GET https://downloads.plex.tv/codecs/c4efa15-4387/linux-x86_64-standard/libmpeg2video_decoder.so (reused)
Oct 21, 2022 22:50:01.418 [0x14c9bf64bb38] DEBUG - Codecs: Downloading current version of mpeg4 decoder
Oct 21, 2022 22:50:01.419 [0x14c9c25cfb38] DEBUG - Jobs: '/usr/lib/plexmediaserver/CrashUploader' exit code for process 371 is 0 (success)
Thank you for this.
I’ve reached out to Engineering.
On Monday, we’ll try to recreate the problem and see where things are failing.
In the interim, please reinstall a lower version of PMS if possible so you can keep running.
Everything seems to be running fine so far at my end
sid@kino:~$ uname -a
Linux kino 5.19.0-2-rt-amd64 #1 SMP PREEMPT_RT Debian 5.19.11-1 (2022-09-24) x86_64 GNU/Linux
sid@kino:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description:    Debian GNU/Linux bookworm/sid
Release:        testing
Codename:       bookworm
sid@kino:~$
sid@kino:~$ hostnamectl
 Static hostname: kino
       Icon name: computer-desktop
         Chassis: desktop 🖥️
      Machine ID: b8ca584ef9394a5bb41f2c3ec0f4c830
         Boot ID: 0bf7c30a3e164a1f9bd6d57fb9ccbbd6
Operating System: Debian GNU/Linux bookworm/sid
          Kernel: Linux 5.19.0-2-rt-amd64
    Architecture: x86-64
Firmware Version: A29
sid@kino:~$
I am having the same problem.
juan@saturn:~$ uname -a
Linux saturn 5.4.0-131-generic #147-Ubuntu SMP Fri Oct 14 17:07:22 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
juan@saturn:~$ lsb_release -a
Distributor ID:	Linuxmint
Description:	Linux Mint 20.3
Release:	20.3
Codename:	una
juan@saturn:~$ hostnamectl
   Static hostname: saturn
           Chassis: desktop
        Machine ID: 98efa152958c4f34805b0bb231ee9df9
           Boot ID: 8055734365934007a410a65d8765ba54
  Operating System: Linux Mint 20.3
            Kernel: Linux 5.4.0-131-generic
Service
juan@saturn:~$ systemctl status plexmediaserver.service
     Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
     Active: active (running) since Sun 2022-10-23 17:15:42 CEST; 49min ago
    Process: 7523 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir>
   Main PID: 7525 (Plex Media Serv)
      Tasks: 90 (limit: 18901)
     Memory: 170.0M
             ├─7525 /usr/lib/plexmediaserver/Plex Media Server
             ├─7561 Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Resources/Plug-ins-f4cdfea9c/Framework.b>
             ├─7601 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/l>
             ├─7635 Plex Plug-in [tv.plex.agents.movie] /usr/lib/plexmediaserver/Resources/Plug-ins-f4cdfea9c/Framework>
             ├─7811 Plex Plug-in [tv.plex.agents.music] /usr/lib/plexmediaserver/Resources/Plug-ins-f4cdfea9c/Framework>
             ├─7858 Plex Plug-in [tv.plex.agents.series] /usr/lib/plexmediaserver/Resources/Plug-ins-f4cdfea9c/Framewor>
             └─8114 Plex Plug-in [com.plexapp.agents.localmedia] /usr/lib/plexmediaserver/Resources/Plug-ins-f4cdfea9c/>
Oct 23 17:15:42 saturn systemd[1]: Starting Plex Media Server...
Oct 23 17:15:42 saturn systemd[1]: Started Plex Media Server.
Oct 23 17:15:49 saturn Plex Media Server[7709]: Jobs: Exec of ./CrashUploader failed. (2)
lines 1-19/19 (END)
Plex folks, it shouldn’t be this hard to revert back to an older version, especially when new ones may come out with new bugs.
After much searching and poking around this is what you have to do today:
  1. Head to ArchLinux code repository
  2. Select the version you want, click on commit and copy the appropriate URL. As v1.29 fails here I selected v1.28 hence
wget https://downloads.plex.tv/plex-media-server-new/1.28.2.6151-914ddd2b3/debian/plexmediaserver_1.28.2.6151-914ddd2b3_amd64.deb
sudo dpkg -i plexmediaserver_1.28.2.6151-914ddd2b3_arm64.deb
Does PMS continue to function?
If so, IGNORE IT for now please.
In the future, it’s always a good idea to keep a local copy of a few versions.
This way you’ll have your own backup copy in case something happens.
I have same message. Jobs: Exec of ./CrashUploader failed. (2)
Running 1.29.2.6334-817e19b35 in docker (plexinc/pms-docker:plexpass) on UnRaid. Plex is running fine. Seeing this message upon restart of Plex for last month.
Just sharing - I’ve read messages/status above and will wait for engineering update.
up, feedback on the problem
Thanks again for confirming.
Engineering does have an open ticket on this.
For now :sunglasses:
My Plex media server configured in Ubuntu 22.10 is working fine but in the last line of the status I always see the error message as below where it says “Jobs: Exec of ./CrashUploader failed”.
root@ubuntu:/opt/plexmedia# systemctl status plexmediaserver
? plexmediaserver.service - Plex Media Server
Active: active (running) since Fri 2022-11-04 12:24:16 EDT; 1h 38min ago
Process: 7533 ExecStartPre=/bin/sh -c /usr/bin/test -d “${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}” || /bin/mkdir -p “${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}” (code=exited, status=0/SUCCESS)
Main PID: 7555 (Plex Media Serv)
Tasks: 90 (limit: 9390)
Memory: 181.6M
CPU: 3min 12.265s
±7555 “/usr/lib/plexmediaserver/Plex Media Server”
±7673 “Plex Plug-in [com.plexapp.system]” /usr/lib/plexmediaserver/Resources/Plug-ins-f4cdfea9c/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.29.1.6316>
±7754 “/usr/lib/plexmediaserver/Plex Tuner Service” /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1.29.1.6316-f4cdfea9c 32600
±7774 “Plex Plug-in [tv.plex.agents.series]” /usr/lib/plexmediaserver/Resources/Plug-ins-f4cdfea9c/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.29.1.6>
±7961 “Plex Plug-in [tv.plex.agents.movie]” /usr/lib/plexmediaserver/Resources/Plug-ins-f4cdfea9c/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.29.1.63>
±8158 “Plex Plug-in [tv.plex.agents.music]” /usr/lib/plexmediaserver/Resources/Plug-ins-f4cdfea9c/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.29.1.63>
±8247 “Plex Plug-in [com.plexapp.agents.localmedia]” /usr/lib/plexmediaserver/Resources/Plug-ins-f4cdfea9c/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version >
Nov 04 12:24:19 ubuntu Plex Media Server[7646]: --platform arg Platform string
Nov 04 12:24:19 ubuntu Plex Media Server[7646]: --platformVersion arg Platform version string
Nov 04 12:24:19 ubuntu Plex Media Server[7646]: --vendor arg Vendor string
Nov 04 12:24:19 ubuntu Plex Media Server[7646]: --device arg Device string
Nov 04 12:24:19 ubuntu Plex Media Server[7646]: --model arg Device model string
Nov 04 12:24:19 ubuntu Plex Media Server[7646]: --sentryUrl arg Sentry URL to upload to
Nov 04 12:24:19 ubuntu Plex Media Server[7646]: --sentryKey arg Sentry Key for the project
Nov 04 12:24:19 ubuntu Plex Media Server[7646]: --version arg Version of the product
Nov 04 12:24:19 ubuntu Plex Media Server[7646]: --allowRetries arg Whether we will allow retries
Nov 04 12:24:45 ubuntu Plex Media Server[7798]: Jobs: Exec of ./CrashUploader failed. (2)
Still waiting for Engineering to fix it.
Bump for attention - Having similar issue on unraid 6.11.2 docker containter (Docker Hub)
Stopping Plex Media Server.
[cont-finish.d] executing container finish scripts…
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 40-plex-first-run: executing…
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: executing…
[cont-init.d] 50-plex-update: executing…
[cont-init.d] done.
[services.d] done.
No need to keep bumping me.
I’m getting whiplash :stuck_out_tongue:
:rofl:
We MUST WAIT for engineering to fix it.
