Setting corruption, HD Homerun disappeared, can't re-add
Server Version#: 1.30.1.6497
Tuner Make/Model: HDHR5-2US, version 20221205
I haven’t noticed when, but some time ago, my HD Homerun tuner disappeared from Plex. If I try to re-add it in the settings, it dosn’t do anything. While trying to re-add, in the logs, I see the following:
Jan 06, 2023 14:12:18.149 [5060] DEBUG - [Req#552b] Grabber: Checking device URI http://10.1.1.31
Jan 06, 2023 14:12:18.150 [5060] DEBUG - [Req#552b/HCl#28a] HTTP requesting GET http://10.1.1.31/discover.json
Jan 06, 2023 14:12:18.159 [9084] DEBUG - [HttpClient/HCl#28a] HTTP/1.1 (0.0s) 200 response from GET http://10.1.1.31/discover.json
Jan 06, 2023 14:12:18.159 [5060] DEBUG - [Req#552b/HCl#28b] HTTP requesting GET http://10.1.1.31/lineup_status.json
Jan 06, 2023 14:12:18.170 [9084] DEBUG - [HttpClient/HCl#28b] HTTP/1.1 (0.0s) 200 response from GET http://10.1.1.31/lineup_status.json
Jan 06, 2023 14:12:18.190 [5060] DEBUG - [Req#552b] Grabber: tv.plex.grabbers.hdhomerun called the probe of http://10.1.1.31 a success.
Jan 06, 2023 14:12:18.190 [5060] DEBUG - [Req#552b/Grabber/HCl#28c] HTTP requesting GET http://10.1.1.31/discover.json
Jan 06, 2023 14:12:18.199 [9084] DEBUG - [HttpClient/HCl#28c] HTTP/1.1 (0.0s) 200 response from GET http://10.1.1.31/discover.json
Jan 06, 2023 14:12:18.199 [5060] DEBUG - [Req#552b/Grabber/HCl#28d] HTTP requesting GET http://10.1.1.31/lineup_status.json
Jan 06, 2023 14:12:18.210 [9084] DEBUG - [HttpClient/HCl#28d] HTTP/1.1 (0.0s) 200 response from GET http://10.1.1.31/lineup_status.json
Jan 06, 2023 14:12:18.230 [5060] INFO - [Req#552b/Grabber] The device was already discovered at http://10.1.1.31, updating URI
Jan 06, 2023 14:12:18.231 [12692] DEBUG - Completed: [127.0.0.1:3338] 200 POST /media/grabbers/tv.plex.grabbers.hdhomerun/devices?uri=10.1.1.31 (14 live) GZIP 81ms 1007 bytes (pipelined: 3)
Jan 06, 2023 14:12:18.774 [9084] DEBUG - [HttpClient/HCl#288] HTTP/1.1 (2.4s) 200 response from POST http://127.0.0.1:32600/devices/discover (reused)
Jan 06, 2023 14:12:18.775 [12692] DEBUG - Completed: [127.0.0.1:2652] 200 POST /media/grabbers/devices/discover (14 live) GZIP 2504ms 1007 bytes (pipelined: 45)
It appears as if there are leftover settings that prevents me from re-adding it. Any way to clean the DVR settings and start anew? Best regards,
I also see these logs in the background, showing it keeps updating its channel list:
DVR:Device: Device device://tv.plex.grabbers.hdhomerun/1064612F was already known, refreshing database info
Yet, there’s no DVR in Live TV and the settings menu has the “configure new tuner” prompt.
You can try this. stop the server from running then in Appdata\local\Plex Media Server\Plug-in Support\Databases and then delete three files that start with tv.plex.providers.epg...
That fixed it right away! Thank you very much!
