KPN iTVonline
Rasplex ondersteund nu wel channels er is een beta namelijk.
Applog:
2013-12-18 22:46:14,500 (146c8) :  INFO (logkit:16) - iOS
2013-12-18 22:46:14,502 (146c8) :  DEBUG (services:615) - Found a service matching 'http://www.itvonline.nl/?channelId=100' - iTVonline (com.plexapp.plugins.itvonline)
2013-12-18 22:46:14,503 (146c8) :  DEBUG (runtime:49) - Received packed state data (80 bytes)
2013-12-18 22:46:14,505 (146c8) :  DEBUG (runtime:49) - Received packed state data (80 bytes)
2013-12-18 22:46:14,506 (146c8) :  DEBUG (services:615) - Found a service matching 'http://www.itvonline.nl/?channelId=100' - iTVonline (com.plexapp.plugins.itvonline)
2013-12-18 22:46:14,507 (146c8) :  DEBUG (runtime:49) - Received packed state data (80 bytes)
2013-12-18 22:46:14,509 (146c8) :  DEBUG (services:615) - Found a service matching 'http://www.itvonline.nl/?channelId=100' - iTVonline (com.plexapp.plugins.itvonline)
2013-12-18 22:46:14,509 (146c8) :  DEBUG (runtime:49) - Received packed state data (80 bytes)
2013-12-18 22:46:14,509 (146c8) :  INFO (logkit:16) - iOS
2013-12-18 22:46:14,513 (146c8) :  DEBUG (runtime:106) - Sending packed state data (110 bytes)
2013-12-18 22:46:14,513 (146c8) :  DEBUG (runtime:914) - Response: [200] MediaContainer, 50201 bytes
Syslog:
Dec 18, 2013 22:48:59:614 [83024] DEBUG - Request: GET /status/sessions [192.168.2.11:36089] (7 live)
Dec 18, 2013 22:48:59:614 [83024] DEBUG - We found auth token (znavqGiwsRaqgQvo1JML), enabling token-based authentication.
Dec 18, 2013 22:48:59:614 [83024] DEBUG - Came in with a super-token, authorization succeeded.
Dec 18, 2013 22:48:59:619 [83640] DEBUG - Request: GET /status/sessions [192.168.2.11:36090] (7 live)
Dec 18, 2013 22:48:59:619 [83640] DEBUG - We found auth token (znavqGiwsRaqgQvo1JML), enabling token-based authentication.
Dec 18, 2013 22:48:59:619 [83640] DEBUG - Came in with a super-token, authorization succeeded.
Dec 18, 2013 22:48:59:624 [83024] DEBUG - Request: GET /status/sessions [192.168.2.11:36091] (7 live)
Dec 18, 2013 22:48:59:624 [83024] DEBUG - We found auth token (znavqGiwsRaqgQvo1JML), enabling token-based authentication.
Dec 18, 2013 22:48:59:624 [83024] DEBUG - Came in with a super-token, authorization succeeded.
Dec 18, 2013 22:49:00:220 [83640] DEBUG - Request: PUT /video/:/transcode/session/2z6m3a07e4eljtt9/progress?progress=7.6&size=-22&remaining=12717 [127.0.0.1:50405] (8 live)
Dec 18, 2013 22:49:00:220 [83640] DEBUG -  * progress => 7.6
Dec 18, 2013 22:49:00:220 [83640] DEBUG -  * size => -22
Dec 18, 2013 22:49:00:220 [83640] DEBUG -  * remaining => 12717
Dec 18, 2013 22:49:00:222 [83640] DEBUG - HLS segment range: 0 - 18 average bitrate: 3.99 Mbps
Dec 18, 2013 22:49:00:222 [83640] DEBUG - We want 6 segments ahead, last returned was 1 and max is 18.
Dec 18, 2013 22:49:00:222 [83640] DEBUG - It took 0.000000 sec to serialize a list with 0 elements.
Dec 18, 2013 22:49:02:233 [83024] DEBUG - Request: PUT /video/:/transcode/session/2z6m3a07e4eljtt9/progress?progress=7.7&size=-22&remaining=12989 [127.0.0.1:50414] (8 live)
Dec 18, 2013 22:49:02:234 [83024] DEBUG -  * progress => 7.7
Dec 18, 2013 22:49:02:234 [83024] DEBUG -  * size => -22
Dec 18, 2013 22:49:02:234 [83024] DEBUG -  * remaining => 12989
Dec 18, 2013 22:49:02:236 [83024] DEBUG - HLS segment range: 0 - 18 average bitrate: 3.99 Mbps
Dec 18, 2013 22:49:02:236 [83024] DEBUG - We want 6 segments ahead, last returned was 1 and max is 18.
Dec 18, 2013 22:49:02:236 [83024] DEBUG - It took 0.000000 sec to serialize a list with 0 elements.
Error op ipad:
De bewerking kan niet worden voltooid
Er heeft zich een onbekende fout voorgedaan (-12880)
Hoop dat je er iets aan heb.
Mvg,
Cylon
Bedankt voor je logs
Ik ga er dit weekend is goed naar kijken
Ik heb hem werken gekregen op de iphone, maar nu werkt hij niet meer op plex home theater??
Loek
Loek wat is de status van de updates?
Op home theater / ipad / web channel werkt het niet zie log files die ik al eerder heb gegeven.
Mvg,
Cylon
Loek
Probeer deze versie is.
Link : https://www.dropbox.com/s/sryygfzka5mm9nc/iTVOnline.bundle-V0.19.rar
Ik heb deze getest op PHT en de web Client. Hierop deze hij het. Hij werkte echter niet op mijn Iphone en mijn rasplex
Loek
De eerste test gedaan via de web interface, en het werkt!!
Zou je later laten weten of het ook werkt via rasplex en ipad etc.
Mvg,
Cylon
Loek
Ik heb net de laatste update van de plexapp voor de iphone gedownload. Het afspelen van live tv werkt nu ook op mijn iphone
Loek
Ik heb op m'n Synology DS1511+ nu Plex Versie 0.9.7.28 (geen idee wat dat verder betekent, nieuw met Plex). Heb de .bundle folder in alle mogelijke folders gezet die ik kon vinden, maar ik zie nergens 't kanaal en zoeken binnen Plex levert ook geen resultaten op.
Doe ik iets fout?
Misschien is het deze map.
Linux:
/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins
Ik heb zelf geen synology maar het lijkt op linux te werken.
Loek
Linux:
Loek
Nope, /var/lib staat geen plexmediaserver/ in..
Ik heb het effe opgezocht en deze map zou het moeten zijn
/volume1/Plex/Library/Application Support/Plex Media Server/Plug-ins
Loek
Hallo Loek,
Daar ben ik weer, tijdje weg geweest. Heb hem zojuist ook weer even geinstalleerd v0.19 versie uit je dropbox. Op een synology met linux-PMS Laatste versie.
In de web Interfase werk alles perfect (TV kijken, gids bekijken, bij opaname plannen/instellen krijg ik een error, maar die gebruik ik niet, meer voor jou info)
Op de iPAD en iPhone5, 4s werkt alles perfect. (TV kijken, gids bekijken) kanaal start meteen (sneller als de KPN app op de ipad)
Op de Windows PMC werkt alles perfect (TV kijken, gids bekijken) zappen/schakelen tussen kanalen gaat als een dolle, bijna sneller dan de gewone TV (hihi)
Je hebt echt een mooi stukje werk verricht Loek! Ik zal nog eens even voor je kijken of ik de logo's compleet voor je kan krijgen. Welke resolutie/afmeting zou het beste zijn? Wil je glans of mat? wellicht kan ik dat aanpassen. :-) kan wel even duren, heb niet altijd tijd. Maar ik wil je graag helpen. Ik ben echt blij met het resultaat.
mvg
Henk
net ook nog even getest op de Apple TV (aTV2) met plex connect, en die werk ook perfect met KPN iTV online!
morgen zal ik nog even op de raspberry PI proberen B)
Ik kan trouwens ook trailers kijken uit de videotheek, videos huren weet ik niet... (had geen 4 euro over om dat te testen)
uitzending gemist kan ik ook kijken.
mvg
Henk
Loek,
Ik heb de TV logo's bij elkaar gezocht. Ze zijn met een tranparante achtergrond, dit is wel mooi denk ik. Enige is dat bij sommige logo's zoals NED 1,2,3 net5 en dergelijke het logo even naar links uitgericht moet worden om het logo te centreren. (Maar dit zie je zo, wat ik bedoel) Ik weet niet of je dat voor elkaar kunt krijgen. Mocht dit niet zo zijn laat het dan even weten, wellicht dat ik er dan nog wat aan kan doen. volgens mij heb ik ze allemaal compleet. Als je nog wat mist veneem ik het graag
https://www.dropbox.com/s/v83a1xhcdk724hn/TV%20Logos%20Transparant.zip
Mvg,
Cylon
Mooi om te horen dat het werkt
Hallo Loek,
mvg
Henk
mooi om te horen dat zoveel clients ondersteund worden. Wat logo's betreft is is groter altijd beter, het duurt alleen langer om ze te laden. ik heb even naar de andere plugins gekeken en deze gebruiken meestal 512x512 voor de afmetingen van hun logo's. voor de rest vind in de logo's die jij een tijd geleden heb gegeven erg mooi, maar betere ideëen zijn altijd welkom
mvg
Henk
raspberry pi heb ik zelf ook geprobeerd. hier kreeg in alleen geen beeld bij. ik denkt dat dit komt omdat je een mpeg licence key nodig hebt.
verder is het ook niet mogelijk om films te huren omdat ik er ook geen 4 euro voor over had om uit te zoeken hoe dit werkte dus als je een film probeert te huren dan krijg je een foutmelding met het bericht dat dit niet ondersteund word.
verder heb ik de eerst post aangepast met versie 1.0.1. als het goed is zijn hier alle problemen mee verholpen  :D
Loek
Loek,
ik heb net alle logo's toegevoegd. ik denk alleen dat we alle plaatsje vierkant moeten maken want een hoop van de plaatsje vallen nu buiten het beeld. verder denk ik dat we een achtergrond moeten gebruiken omdat je anders bij plex home theater een gek beeld krijg.
dit is de link om het resultaat te bekijken
https://www.dropbox.com/s/bae8gn25h03h21c/iTVOnline.bundle-V1.0.1%20-%20alt%20images.rar
ik weet niet of jij goed bent met programma's als photoshop. ik kan het een klein beetje maar ik krijg het nooit echt mooi.
dit is denk ik wel een goede site om alle logo's vandaan te halen. dan moeten we alleen nog een goede onderlegger hebben
http://www.lyngsat-logo.com/tvcountry/nl.html
Loek
Loek
Dat klopt loek, zonder MPEG license doet hij niets
Loek
Die site had ik ook gevonden. wat betreft logos, dat ziet er inderdaad niet uit zo.
Ik ben geholpen met het feit dat ik nu weet dat ze 512x512 pixtels moeten zijn. Persoonlijk vind ik een logo met een transparante achtergrond mooier omdat het er anders allemaal zo vierkant uit komt te zien. Ziet er zo goedkoop uit.
Maar ik ga er eens mee aan de gang. Ik probeer zowel tranparant als niet transparant (te maken) en dan kunnen we kijken wat het mooiste is.
ik ben zelf ook niet zo goed met photoshop, maar wil daar wel wat mee gaan proberen. Is wel leuk als het er straks allemaal mooi uitziet.
je hoor weer van mij.
mvg
Henk
Hi Loek,
Ik heb de logo's gemaakt in twee versies met tranparante achtergrond. 512x512 pixtels, big logo's en small logo's. Sommige heb ik custom moeten maken, omdat ze er gewoonweg niet zijn. Nu kunnen we eerst wellicht eens kijken hoe ze staan en uitkomen en of het allemaal past. Mocht je later nog een achtergrond er achter willen, zoals clossie, mat of 3d met een vaste achtergrond kleur dan kan dat altijd nog, het meeste werk was het maken van de logo's ;)
ik heb tevens een KPN icon-default.png en een Telford icon-default.png gemaakt, ik vind ze wel mooi. (die zijn tevens 512x512) Ik weet alleen niet hoe je dit op kan lossen voor de gebruiker, het zou mooi zijn als een gebruiker kpn instellingen maakt en dat dan de KPN icon-default.png wordt gebruikt en met telford de Telford icon-default.png je kan ze natuurlijk altijd zelf hernoemen naar icon-default.png dan pakt hij hem natuurlijk ook gewoon op. je zou dan een telford versie en een KPN versie kunnen publiseren ofzo in je github :P
ik ben benieuwd of ze werken, je kan ze downloaden via de onderstaande link,
laat maar even weten als je nog aanpassingen nodig hebt, commentaar is altijd welkom!
https://www.dropbox.com/s/lcc03sk3188d5er/TV%20Logos%20PNG%20-%20512x512%20-%20Big%20Logo%20v1.1.zip
https://www.dropbox.com/s/g5ut8o7mordqxh5/TV%20Logos%20PNG%20-%20512x512%20-%20Small%20Logo%20v1.1%202.zip
ik heb de logo's toegevoegd aan de plugin het ziet er nu al een stuk beter uit.
de plugin is hier te downloaden
https://github.com/loek17/iTVOnline.bundle/archive/master.zip
voor het telfort en kpn logo heb ik het zo gemaakt dat als je de instellingen veranderd en de plex server opnieuw opstart dat het logo dat veranderd naar de juiste provider
het opnieuw opstarten is alleen nodig voor het veranderen van het logo.
Loek
Loek,
Dat begint er op te lijken zo. In de web interface en op de iphone en ipad ziet het er wel mooi uit zo, maar in de home theator nog niet helemaal. Ik moet daar nog iets schuiven met logo's om ze helemaal goed te krijgen. Daar ga ik deze week even mee aan de slag.
Nu nog een achtergrond kleur achter de logo's. Dit moet en lichte kleur zijn, omdat anders de logo's niet zichtbaar zijn, zo moeten er duidelijk uit springen.
nu kan ik per logo kijken wat de mooiste kleur is bij het logo, maar eenvoud vindt ik ook wel wat hebben. in de link een paar voorbeeldjes. Ik hoor graag wat jij het mooiste vindt, logo's met achtergrond kleuren door elkaar, of allemaal de zelfde kleur achtergrond Persoonlijk vindt ik de gele wel mooi.
Mocht je nog andere ideeen hebben voor achtergrond en kleur, let me no.
https://www.dropbox.com/s/bsbcb3h7c5278xf/voobeeld%20logos.zip
mvg
Henk
