Labelling extras
Server Version#: Versión 3.102.0
Player Version#: Versión 3.102.0
Hello,
I have a short film I labelled:
Salut les cubains (1963) Agnès Varda.avi
accompanied by the subtitles files:
Salut les cubains (1963) Agnès Varda.es.srt
Salut les cubains (1963) Agnès Varda.pt.srt
There is an interview file and its subtitles for this film. I labelled them
Agnès Varda presenta Salut les cubains (1963) Agnès Varda-interview.avi
and the subtitles
Agnès Varda presenta Salut les cubains (1963) Agnès Varda-interview.es.srt
Agnès Varda presenta Salut les cubains (1963) Agnès Varda-interview.pt.srt
My problem is the interview file and the subtitles don’t appear at the film’s page. Can someone help me? Thanks so much for your time and generosity.
External subtitles are not supported for movie extras.
How many other files are located in the folder with the extra?
Hi, Otto, thank you for your kind reply and help.
I created one folder,
The files inside are
Salut les cubains (1963) Agnès Varda.es.avi
Salut les cubains (1963) Agnès Varda.pt.avi
Thank you so much. Kind regards,
Anyway, if external subtitles are not supported for movie extras, I think I will make this interview a second part of the film, to be able to play it with the subtitles. What do you think about that?
I can’t recommend that.
Get yourself MKVtoolnixGUI
Install it.
then drop all 3 files of the interview into the program window
click on ‘Start Multiplexing’
Is this some kind of documentary? Make sure that it is ‘matched’. Otherwise you won’t be able to use any local extras.
If it is not listed on TheMovieDatabase, match it to the Personal Media agent.
https://support.plex.tv/articles/201018497-fix-match-match/
Thank you so much. You are SO kind!!
Yes, the film is a documentary, and the second one is the director speaking about it.
Hi, Otto,
I did everything you said.
The new file is now: Agnès Varda presenta Salut les cubains (1963) Agnès Varda-interview.mkv
but, again, it doesn’t appear as Extras, or as anything else…
Please copy the content of the Plex XML info of this movie into here.
Archivos
Eliminar archivos
H:\Peliculas\Salut les cubains (1963) Agnès Varda\Salut les cubains (1963) Agnès Varda.avi
Media
Duración 27:26
Bitrate 1841 kbps
Width 720
Height 494
Aspect Ratio 1.66
Video Resolution 480p
Container AVI
Video Frame Rate PAL
Video Profile simple
Parte
Duración 27:26
File Salut les cubains (1963) Agnès Varda.avi
Size 361.33 MB
Container AVI
Indexes sd
Codec MPEG4
Bitrate 1700 kbps
Anamorphic true
Bit Depth 8
Chroma Location left
Chroma Subsampling 4:2:0
Frame Rate 25 fps
Height 494
Nivel 1
Pixel Aspect Ratio 16:15
Profile simple
Ref Frames 1
Width 720
Display Title 480p (MPEG4)
Codec MP3
Canales 2
Bitrate 128 kbps
Audio Channel Layout stereo
Sampling Rate 48000 Hz
Stream Identifier 1
Display Title Desconocido (MP3 Stereo)
Codec SRT
Idioma English
Display Title English (SRT Externo)
Codec SRT
Idioma Español
Display Title Español (SRT Externo)
Sorry, this is not the Plex XML info
I should say sorry
:upside_down_face:
Let me try again.
I got it, I sent you the file info. When I clicked on See XML, a new window opens…but there is nothing in it.
https://192-168-1-12.00cebc5bd1c54e978524fc01ce9bfe5a.plex.direct:32400/library/metadata/5492?checkFiles=1&includeExtras=1&includeBandwidths=1&X-Plex-Token…
Sorry, I cannot open this link. It is only valid for you.
That’s why I wrote “the content”.
Copy & paste
I can only see a blank page. I took the whole folder out of where I store the films and run “search for files in the library”. The movie disappeared. I am copying it again. Let’s see what happens now.
Nothing happened. It’s the same…
Oh, you are using that browser.
A CMD-click (or right-click) on that white page should allow you to ‘view source’. It is this I’m after.
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="1" librarySectionTitle="Películas" librarySectionUUID="96f5b519-b5bc-4c60-9416-bd3f26a0392c" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1560436154">
<Video ratingKey="5496" key="/library/metadata/5496" guid="com.plexapp.agents.imdb://tt0057466?lang=en" librarySectionTitle="Películas" librarySectionID="1"librarySectionKey="/library/sections/1" studio="Ciné Tamaris" type="movie" title="Salut les Cubains" originalTitle="Salut les Cubains" summary="A half-hour photo montage made up of 1500 out of over 4000 pictures Agnès Varda took while vacationing in Cuba. It deals with the revolution led by Fidel Castro." rating="7.7"year="1963" thumb="/library/metadata/5496/thumb/1560794843" art="/library/metadata/5496/art/1560794843" duration="1646480" originallyAvailableAt="1963-12-09"addedAt="1560794761" updatedAt="1560794843">
<Media id="10376" duration="1646480" bitrate="1841" width="720" height="494" aspectRatio="1.66" audioChannels="2" audioCodec="mp3" videoCodec="mpeg4"videoResolution="480" container="avi" videoFrameRate="PAL" videoProfile="simple">
  <Part accessible="1" exists="1" id="10671" key="/library/parts/10671/1546105556/file.avi" duration="1646480" file="H:\Peliculas\Salut les cubains (1963) Agnès Varda\Salut les cubains (1963) Agnès Varda.avi" size="378883772" container="avi" indexes="sd" videoProfile="simple">
    <Stream id="30706" streamType="1" codec="mpeg4" index="0" bitrate="1700" anamorphic="1" bitDepth="8" chromaLocation="left" chromaSubsampling="4:2:0"frameRate="25.000" height="494" level="1" pixelAspectRatio="16:15" profile="simple" refFrames="1" width="720" displayTitle="480p (MPEG4)"/>
    <Stream id="30707" streamType="2" selected="1" codec="mp3" index="1" channels="2" bitrate="128" audioChannelLayout="stereo" samplingRate="48000"streamIdentifier="1" displayTitle="Desconocido (MP3 Stereo)"/>
    <Stream id="30708" key="/library/streams/30708" streamType="3" codec="srt" language="English" languageCode="eng" displayTitle="English (SRT Externo)"/>
    <Stream id="30709" key="/library/streams/30709" streamType="3" selected="1" codec="srt" language="Español" languageCode="spa" displayTitle="Español (SRT Externo)"/>
  </Part>
</Media>
<Genre id="445" filter="genre=445" tag="Documentary"/>
<Director id="11559" filter="director=11559" tag="Agnès Varda"/>
OK, this is showing me that this film is matched to the Plex Movie agent.
Settings - Server - Agents - Movies - Plex Movie
Is the line ‘Local Media Assets’ activated?
The problem is not with the film but with the interview file, which I cannot see in a small picture in the film’s page.
