Lack of options for meta data collection
Server Version#:
Is there any way to add a alternate metadata service for my server? anidb.net has a far better and more accurate listing for anime titles and especially cover art availability than the two services they search, I’d love to have more options as well as a better looking library that doesn’t randomly lack cover art. Alternatively, I’d just be happy with a way to select my own cover art for the missing series and not have to mess about with updating sites (that they use by default) that may or may not fix the issue.
https://support.plex.tv/articles/200220717-local-media-assets-tv-shows/
Ok and thanks for the info, I’m new to setting these up so I’ll try it out and see if I can’t figure out how to set it all up. Do you know if it’ll integrate into the over all system so when I add something and scan for new shows it will be able to get everything on it’s own?
Not sure what you’re asking here.
I mean will it automatically get the info like the current metadata searches and fill out all the info like the stock system does.
Yes. Otherwise there’d be no point.
