Leaving items unwatched with about 5 minutes left?
Recently no matter the length of the video I play, upon completion it stays on my dashboard with about 5 minutes left, and if I get near the end of an item and try to go back, it seems to crash and I have to play the item again from the beginning and fast forward to where I want. How do I fix this?
You Don’t.
Are you using the FireTV App, or some other unfortunate Android Thingy?
If you are - you have discovered one of the plethora of maladies infecting everything Android.
Unfortunately.
@JuiceWSA said:
You Don’t.
Unfortunately.
Yes. On the FireTV Box. Damn.
Is it some new bug then or something? It only started happening recently.
Yea, apparently.
If you get out there in ‘no-man’s-land’ - in the void area when Plex thinks you’ve watched enough and should move on to the next item… there will be no backing up a bit (like to see something in the credits you missed). Locks her right up.
It’s probably already been reported here:
https://forums.plex.tv/categories/android-tvs
But considering that the debris is still falling out of the sky over there, and support was seen running from the stadium with their hair on fire, a little bug like this one will get lost in the noise.
Perhaps a helpful Admin will ■■■■■■ this thread up and put it over there for you.
Just in case someone may notice it - and add it to the big list of things that need fixing.
Here’s another one that just popped up
Same here. Nvidia shield
