LG TV doesn’t show thumbnails when skipping forward
TV: LG OLED55C8PJA
Plex Client: 5.0.10
Plex Platform: 4.1.0
When playing a movie or episode, there used to be preview thumbnails when you skipped forward or backward on the time position bar. There are no thumbnails any more, which makes it harder to find things.
Are these removed, broken or not done yet?
If that app has the ‘new android player’ you get to the VPTs by pressing up D-Pad twice to get to the scrub bar - then left or right as required.
If that doesn’t work - they may not be in your app yet.
I don’t know your app.
Did you enable the Early Access release?
It is not yet at parity with the current non-beta version.
