New LG smart TV (12.12.2020) with webos 4.75.07 wont update to latest plex app
Any suggestions how to update / install ??
Please forward your TV model
The model is - 24TN510S
I’m sorry to tell you, your model is not a UHD model and is not supported for the Preview app.
https://support.plex.tv/articles/204080173-which-smart-tv-models-are-supported/
I hadn’t appreciated the model had to be UHD !!! Is there plans for non UHD do you know or should I look to change now. The new download looks far better to use.
You can say that again, it’s awesome. But does not help you with that model. If your happy with that TV and Resolution, buy a secondhand Roku Ultra or apple TV 4k model, so you stay in front of any changes.
But If looking at a new TV a LG OLED is the way to go, make sure even with Nanocell models it has a alpha 7 or 9 processor.
Thanks for the advice, I’ll take a look
Thanks again
