Server Version#: 1.21.2.3939
Player Version#: 1.27.1.1571-2fface66
Hi Guys,
is it possible that only the admin account can sort the libarys AND that all other managed user have the same libary order ? Actually when I adding a new libary I change the order so that the libarys are sort by alphabet a to z. But the problem is that this order is only for my admin user and only for the pc (windows) app. When I use Plex on an other device with my admin user I must change the order again. With the managed user is the same problem. the user must change the order on every device who there are using plex.
So I will change the order one for all user and devices so that when I changed the order and an user is loggin in the app, the app synchronize the sort order with the server.
This is unfortunately not possible.
Each user can customize his sidebar and the home page individually.
hi, this is in some cases ok. But I have a big libary and the firt sort order is from a to z. So after sorting I added the new user. They have the same sort order. Butr now when I adding some new libaries there are added under the last libary begins with Z. So the sort order is now not correct and looks not so good. So that every user must sort new by him self is acceptable. But why mus the user sort on every device again ? to example on amazon fire tv stick in living room, user A sort the libaries. when user A now change the room and goes to the bedroom where the püley app is installed on the tv, he must sort the libaries again. Is that a bug or an error ?
And would it be planned that the admin was only permitted to sort the libarys ?
