Libraries Not Updating
Server Version#: 1.17.0.1841-d42cfa161
I did update to 1.18.0.1913-e5cc93306 and that’s when the problem started. Only random items would start to appear. 4 new items in the same folder and only 1 item would appear. Sometimes the metadata would load and now - no metadata is loading. I am unable to access Server settings as they are always Unavailable. I’ve turned IPv6 off, uninstalled and reinstalled the version that was working… I am still getting
“Oct 16, 2019 07:33:48.471 [36824] ERROR - Error issuing curl_easy_perform(handle): 7
Oct 16, 2019 07:33:48.471 [10696] ERROR - Error issuing curl_easy_perform(handle): 7
Oct 16, 2019 07:33:48.471 [10696] WARN - HTTP error requesting GET http://127.0.0.1:32400/:/metadata/notify/changeItemState?librarySectionID=3&metadataItemID=23523&metadataType=2&state=3&metadataState=queued (0, No error) (Failed to connect to 127.0.0.1 port 32400: Address not available)
Oct 16, 2019 07:33:48.471 [36824] WARN - HTTP error requesting GET http://127.0.0.1:32400/system/agents/update?mediaType=2&force=1&guid=com.plexapp.agents.thetvdb%3A%2F%2F326241%3Flang%3Den&id=23523 (0, No error) (Failed to connect to 127.0.0.1 port 32400: Address not available)”
I am able to access Plex locally and remotely. Sooooooo? Any help would be greatly appreciated.
I am having the exact same issue since the update with a similar error:
Error issuing curl_easy_perform(handle): 56
HTTP error requesting GET http://192.168.0.254:45514/agent.xml (0, No error) (Recv failure: Connection was reset)
SSDP: Error parsing device schema for http://192.168.0.254:45514/agent.xml
I added 10 movies to my server, 4 had no issues with metadata and the other 6 will not grab any metadata.
If you find a solution please let me know.
So I use a VPN and for some reason today I thought about disconnecting (I stay connected 24/7) and attempt to update and it worked… so something about my VPN is causing the issue. Thought it was weird that more people were not reporting this issue so it had to be local.
