Library configuration does not get saved and always stays as Recommended
  • Library display configuration
I’m not sure what configuration you are referring to. The selection of recommendation rows?
Do you have “remember selected tab” enabled in whatever Plex player app you are using?
What version of server and what is is running on.
Thank you BigWheel, I had forgotten all about that option :+1: :+1: :+1:
