I configured plex on a synology NAS, The main idea is to organize all my private photos and videos, I have already encountered a problem that I am not able to overcome.
I can only create new libraries if I choose photo libraries !
If you choose any of the other types, movies, TV series, music, other videos, my content is not listed and
do not appears anywhere.
The library is being created normally:
Main menu - Add library - Select type - add folders etc
After the creations my content is only shown if I have chosen PHOTOS on the Select type.
I’ve tested everything, folders with only videos, folders with only photos and mixed folders.
I always have the same result, only works if I choose PHOTOS on the Select type.
And only in that case - PHOTOS on the Select type - I can see everything , photos and videos.
May I augment Tom’s post here with a quick point-of-order for new Synology users?
Synology uses Linux as the OS. It mandates each individual user be given access to specific shares. Please make certain you have given user Plex access to the media share you wish to have Plex index and add to your Library.
