Library Tab will not engage, screen stays on Recommended
I am currently using Pixel 3, I was using Pixel 4 (same issue).
I have the latest Android software (10 with whatever update/July-August security).
there’s a setting in the experience section for “remember selected tab”; and it has a bug. when I have that selected, the app works fine; but if I deselect it, I can’t access my library tabs… the screen will blink and it will return/stay on the recommended tab.
it’s not on my end because I’ve done it on 2 phones and I can literally change the setting and watch the bug go away/return.
What version of the Plex app are you using?
Edit - This bug was in 8.4.2. Should be fixed in the latest 8.5.0. Please update.
great, thank you… 8.4.2.19372 is currently the updated version in the play store, but I’m sure it’ll come to me at some point.
Google music is going bye bye and YouTube music is awful… so I finally moved all my music into Plex with my movies and TV, that’s when I really noticed. thanks for your quick reply, it makes me feel I should be more active in the community and help make Plex even better.
