I have a 7.1 reciever that my ubuntu box plugs into.
I can set my audio to stereo, 5.1 and 7.1 in the sound settings.
Inside plex, the normal options are available as well.
No matter what the source audio is, linux outputs whatever the sound settings are set to (stereo, 5.1, 7.1)
So if everything is set to 7.1 and the source audio is 7.1 it is perfect (star trek into darkness is amazing in 7.1.) But if the source audio is 5.1/6.1, hell even stereo; ubuntu still outputs 7.1 channels thus the reciever cannot scale the audio out to 7.1 via decoding or whatever.
The best way I can describe it is seems the audio is statically mapped to use all 8 channels no matter what.
Is there a way that it can dynamically change based on the audio source output? Seems like chromecast and roku do this?
As a stop gap I have just set everything to 5.1 and let the receiver upscale it to 7.1 which still works pretty damn good.
So 7.1 audio is getting transcoded to 5.1 (or maybe 5.1 is encoded in 7.1, idk,) then sent to the reciever and re-upscaled...
Does this make since?
Let me know if this is possible or if I am trying to have my cake and eat it too.
I know it is pulseaudio, took me a bit to figure out how to get from 5.1 to 7.1. (I learned that dvi to hdmi adapter from my gfx card doesnt support 7.1. I assume its a dvi limitation. Fix by going from hdmi to hdmi.)
I'm not sure what ALSA or audio bitstreaming is, can you explain or provide some links for me to read? I will of course use my googleFu to try to educate myself on it.
My graphics card is a nvidia 560ti.
Not adverse to reformatting. This media pc has been windows 7, ubunutu 12.04, 13.10, steamOS and now 14.04.
Bitstream audio to my reciever so that codecs are pass through my receiver which can decode the original source and/or upsample it from whatever to 7.1
I tried launching the GUI audio controller after but that didnt work, the preferences screen was just blank.
But I went into plex settings and set my audio as the hdmi connected to my onkyo 616 receiver and it works. The menu spits out 2.0 but all videos get pushed out from the original source encode (Dolby, DTS, TrueHD...)
Using an i3 2nd gen chip, micro board. nvidia 560ti gfx running my audio from the mini hdmi in the gfx card to receiver. Ubuntu 14.04
Pasted script incase the linked site ever goes down.
I've yet to see a situation where the two work side by side... in most cases I have seen, it is either one or the other...
From what I have read, ALSA can be a pain, especially when it comes to gaming because of design complexity... i.e the complexity in ALSA architecture does not make it easy for game writers to integrate sound... which is the reason why games writers prefer to work with pulseaudio
I am going to rebuild and see if I can get a side by side going basically by skipping the purge command from step 2 above. If not I guess I can throw in another hdd and just go into a dual boot scenario, HTPC on drive 0 and steamOS or ubuntu14.04+steam on drive 1.
(I will report back if somehow I get the side by side to work.)
